Sigeyi Axo Power Meter Spider
kode54
by kode54
trex wrote:
Tue Mar 08, 2022 6:34 pm
Hi folks,
I purchased AXO SRAM-8-4-110 power meter on Ali a few months ago. I waited a very long time for the crank arms (covid times) and once they arrived I set about fitting them.
Unfortunately before that I noticed a problem with the battery/charging of the power meter itself.
It is as follows:
1. The PM is visible in the app.
2. It shows power and cadence values. Calibration can be performed.
3. Unfortunately when connected to charging cable - charging LED is not illuminated.
4. This results in the fact that the update cannot be performed.
5. What is worse, despite the non-illuminated diode, during charging the battery level changes to 100% after a few minutes. Then, when I unplug the chaging cable - the LED blinks five times and the charging level returns to 94%.
I have tried using different usb chargers, cleaning the contacts, leaving the charge on longer - to no effect.
What can I do in this situation? Do you have any experience with Sigeyi warranty service?
Thanks!
The magnetic connector picks up little metal bits and can lift it off...so I make sure I clean it by a cloth or fingers to make sure before attaching.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
raggi
by raggi
Hi, does anyone know if the AXO-ROTOR-ALDHU-4-110 spider is compatible with Shimano chainrings?
robbosmans
by robbosmans
Yes that’s what it’s designed for
trex
by trex
Yes, this is the first thing I did.
Warranty replacement PM arrived yesterday - looks like everything is ok now.
So kudos to Sigeyi!
kode54 wrote:
Fri Apr 08, 2022 4:41 pm
Hi folks,
It is as follows:
Thanks!
Maxmillian
by Maxmillian
Sigeyi AXO is good
But crank price goes crazy high in china.
kode54
by kode54
@trex...good to know they honor their PMs.
Did you ship back to China?
- Factor LS Disc
trex
by trex
Yes, I had to.
kode54 wrote:
Wed Apr 13, 2022 1:59 pm
Aeo
by Aeo
4.018
Giant TCR Adv Pro Disc '17 · BH Lynx Race Evo '19 · Seraph GR029 '21 · Canyon Inflite AL '14
Aeo
by Aeo
4.019
spartacus
by spartacus
Do these things ever go on sale?
floriansantana
by floriansantana
Just a quick heads up for everyone interested in the AXO for Cannondale Si cranks: You might have to sand away a bit of the plastic body of the PM where the cranks reach out of the spider, otherwise it won’t fit exactly straight to the cranks which causes a wobble of the chainrings and therefore a mess when adjusting the FD.
Do other PM models of the AXO for other cranks have the same problem?
Cannondale SuperSix Evo Disc
Cannondale SystemSix HiMod Disc
@floriansantana
Aeo
by Aeo
4.020
kode54
by kode54
Thx for update reminder when they are available. I never check myself.
- Factor LS Disc
cberg
by cberg
So 6000 km in mine is working (almost) flawlessly. Very fit and forget, the readings seem right except some slightly high peaks when sprinting. Anybody else get this too?
PaulJ
by PaulJ
Is there a source for these in the UK still? Sigeyi.co.uk seems to be down, I last contacted them at the back end of 2021 and they said end of Jan 2022 for more stock of Sram 3bolt 5x110 fitment. I've since emailed them again with no response, and their site never did show more stock of this fitment.
BikeInn shows stock, but I'm hesistant to order from overseas just incase of warranty issues and the associated hassle with a non-UK retailer if there are problems.
