R314
by R314 on Wed Jun 23, 2021 11:40 am
milanv wrote: ↑Wed Jun 16, 2021 7:40 am
RDY wrote: ↑Fri Jun 11, 2021 8:02 pm
So what's the latest on the Sigeyi Axo and Xcadey Xpower spiders? Are they fixed and working well, or is firmware borked again?
I have read all known information and test across the net about both... Several people report bad power figures with X-Cadey, nor Sigeyi. Last information in this thread is, that X-Cadey latest FW corrected power errors experienced before. Is it OK, now? Sigeyi is right from the beginning.
I would like to use it on my second bike with Rotor cranks and chainrings. Thx.
I've been using mine since december on a Sram GXP crankset. Paried with an Edge 130 or PC (via ANT+).
Firmware updates went fine (tried with an Iphone and an android device). I dind't see any extreme prower spikes, maybe because I use
https://intervals.icu/ to analyze my data.
It looks like this:
https://ibb.co/LtL02y0
Aeo
by Aeo on Fri Sep 03, 2021 4:45 pm
I don't think there is a historical list of firmware updates, maybe we can collect something here
2021-07-31 firmware version 4.013
Giant TCR Adv Pro Disc '17 · BH Lynx Race Evo '19 · Seraph GR029 '21 · Canyon Inflite AL '14
kilokilo
by kilokilo on Wed Sep 08, 2021 3:39 pm
hi, do you run oval rotor rings or no-q ?
my axo L/R figures is acting funny, it used to be 50L/50R when stand still and no pressure on the pedal. it become 100/0 now days and when i try to re-calibrate the powermeter on garmin it show calibration error....
where do you guys get support from sigeyi ?
milanv
by milanv on Wed Sep 08, 2021 4:41 pm
kilokilo wrote: ↑Wed Sep 08, 2021 3:39 pm
I ride oval Q Rings 52+36.
gplama
by gplama on Sat Oct 09, 2021 10:52 am
Quick query for anyone with an AXO spider meter - How are your numbers looking if you've compared them to other meters?
I've scrolled back through a few pages of posts and a few indicate they're a little low? (Not a worry with the new scaling in their app....).
MagicShite
by MagicShite on Sat Oct 09, 2021 11:27 am
gplama wrote: ↑Sat Oct 09, 2021 10:52 am
It was a bit low but just slightly lower than Kickr 4. Otherwise the latest firmwares have them about 2.5% higher.
I'm not sure if it has to do with my legs getting stronger or what, it's hard to do a check without them allowing me to flash the older firmwares.
I was testing them to almost 1:1 while trying to regain fitness after recovering from a broken femur. My gut tells me they measure close around 200w while getting a larger separation at higher watts around 250-300. I'm too lazy to do a comparison though haha.
gplama
by gplama on Sat Oct 09, 2021 12:44 pm
MagicShite wrote: ↑Sat Oct 09, 2021 11:27 am
Thanks for the reply. This is really interesting. I've tweaked the unit I have here to be spot-on with the Kickr 5 and Assiomas. It required about the same adjustment. More on this soon....I'm still throwing a few things at it.
MagicShite
by MagicShite on Sat Oct 09, 2021 1:58 pm
gplama wrote: ↑Sat Oct 09, 2021 12:44 pm
O_O do you mean to say you found a discrepancy around 2.5% as well?
I actually have 3 units of these. They match really consistently well to each other.
The 3.719 firmware actually was closest to the Kickr, less than 0.5%, but they wouldn't let me flash that version and would insist the new one's better. *shrugs*
glepore
by glepore on Sat Oct 09, 2021 9:08 pm
I haven't done a run on a kicker or side by side yet, but I've been really happy with mine so far, and the numbers seem to be within a few watts of my other pm's (SRM, Quarq, Stages gen 3). Maybe a touch low along the lines you suggest, but nothing that I'd consider a training liabilty.
Cysco Ti custom Campy SR mechanical (6.9);Berk custom (5.6); Serotta Ottrott(6.
; Anvil Custom steel Etap;1996 Colnago Technos Record
bobinski
by bobinski on Mon Oct 11, 2021 1:46 pm
I am reallyt interested in this PM but it's not compatible with Shimano 8000 series. I have a Scott Addict and by looks of it i would have to upgrade the BB, chain rings and crank as well. Such a shame because then the cost becomes equivalent to other options.
BigBoyND
by BigBoyND on Tue Oct 12, 2021 4:30 am
bobinski wrote: ↑Mon Oct 11, 2021 1:46 pm
Well yes. To install a power meter spider, you need a removable spider. But to your point about price, I agree. The price is too close to a Quarq spider for it to make any sense to me.
