Sigeyi Axo Power Meter Spider
- robbosmans
- Moderator
- Contact:
I know someone who disagrees with Quarq’s reliability. Ask RyanH
I've owned a bunch of power meters (6 Power2Max, 3 Quarqs and Assioma Duo) and the only issues I've ever had were from the Quarqs, went through two units in 6 months, and finally sold the second replacement unit and bought another Power2Max. Will never waste my money on a Quarq again
Yeah, the only unit I had outright fail was a Quarq (I've had powertap, several srms, Quarqs, P2M and now Sigeyi). It was a several year old unit though.
Cysco Ti custom Campy SR mechanical (6.9);Berk custom (5.6); Serotta Ottrott(6. ; Anvil Custom steel Etap;1996 Colnago Technos Record
I'm from Belgium : I can confirm this, I 've ordered from him and everything went smoothly.
I had a quarq crap out too.
Now looking at Power2max (had one, zero issues, sold it with the bike it was on) and Sigeyi. What's you're experience been between the two? On paper Sigeyi is cheaper and lighter.
Both Power2Max and Sigeyi have serve me well on my bikes - I like the Sigyei better and it is very well made.
I don't have any issue at all charging the unit on my partners bike, which is the same spec. The charge cable does 'bounce' off if it's upside down though, as the magnets in the charge cable / charger are reversed. Try flipping it around and it should work fine.
No, neither direction works. Tried the cable from my SRAM 8 bolt AXS Sigeyi, same effect. Both cables snap into place solidly on the SRAM one. I had to duct tape it on in the end.
It has minor accuracy issues due to not cancelling out non-rotational forces. Basically the more extreme the chainline, the less accurate it gets. Non-rotational forces are the bane of many cheap power meters, including big names like Stages.
