Sub 6kg BMC Teammachine SLR01 disc
survivor
by survivor
Weight Weenie experts,
I like BMC Teammachine SLR01 disc and wondering whether it is possible to build one that is sub 6kg?
Below are my component wish list but it seems the best is I could get is 6.16kg. Some of these weights are quote from posts in this forum, some are from manufacturer specification. Any other ideas to lower the weight?
  • Frame: Teammachine SLR01 Size 51cm - 820g
    Fork: Teammachine SLR01 - 350g
    Headset: Teammachine SLR01 - 60g
    Top Cap Expander: Teammachine SLR01 - 10g
    Seatpost clamp: Teammachine SLR01 - 20g
    Seatpost: Darimo T1 Loop Seatpost Aero (BMC) - 95g
    Skewer: Teammachine SLR01 - 60g
    BB: Kogel BB86 - 60g
    Crank: SRM Origin with Power Meter - 539g
    Chainring L: Carbon-Ti X-CarboCam 50 x 110 - 81g
    Chainring S: Carbon-Ti X-RoadCam 36 x 110 - 29g
    Rotors Front: Carbon-Ti X-Rotor SteelCarbon 2 160 - 77g
    Rotors Rear: Carbon-Ti X-Rotor SteelCarbon 2 140 - 65g
    Brakes: Dura Ace R9170 Disc - 260g
    Shifters: Dura Ace R9170 Disc - 320g
    FD: Dura Ace R9150 - 100g
    RD: Dura Ace R9150 - 200g
    Brake Cable: Hydraulic - 70g
    Shift Cable: Di2 cables/battery/junction - 130g
    Cassette: Dura Ace R9150 - 200g
    Chain: KMC DLC11 - 243g
    Chain Catcher: K-Edge Pro Road Chain Catcher - 10g
    Stem: BMC ICS01 100mm - 210g
    Handlebar: Darimo Ellipse 400mm - 124g
    Bartape: Lizardskin DSP 1.8mm - 50g
    Saddle: Bontrager XXX Full Carbon - 65g
    Wheelset: Partington 39R/44R - 1150g
    Tires: GP5000 TL 25C x 2 - 600g
    Pedal: Look Keo Ti Carbon Ceramic - 95g
    Bottle cage: ENVE Carbon x 2 - 36g
    Computer Mount: BMC ICS Garmin Mount - 30g
rollinslow
by rollinslow
survivor wrote:
Mon Nov 11, 2019 9:56 pm
Admire the enthusiasm. You need to add another 100grams to the Look pedals. That weight is per single pedal. Sorry :(
dudemanppl
by dudemanppl
Origin is dummy thicc, do like a Red GXP, sand the arms, do some lighter rings, then do Favero Assiomas.
refthimos
by refthimos
While the +95g for the Look pedals is a bummer, you could lose 85g with a change to Extralite Cyberdisc. Mine weighed in at 1065g actual weight.
EVO1 | 5.37kg
EVO3 | 6.51kg
SystemSix | 8.01kg
P5 | 9070 Di2 | SISL2 SRM | Enve 7.8/FFWD Falcon | Roval 321
T1 | P2Max Type S | Rolf Prima FX58/Zipp Super 9 Disc
alcatraz
by alcatraz
That stem and bar combo is hillarious. 210gr stem and 124gr bars. :D
LewisK
by LewisK
Depends on the ratio, but a 11/25 sram red cassette will save you about 50g
CarbonWorks cages are 8g each
Ditch the out front mount and use bands that tie around the stem, there’s another 25g gone
The chain should be a bit lighter than that, as think you’ve stated uncut length!
Deda do some bar tape around 30g, not sure what it’s called but someone will be along shortly that’s knows.
You’d possibly save 200g ish with a frame and fork paint strip, but that’s quite drastic and you may like the look of the colour as it is.
hannawald
by hannawald
Deda traforato bar tape
PYC 1101 chain
Speedplay with chinese titanium axles and hardware
You can loose a lot with Hutchinson Fusion 11 Storm Galactik
WorkonSunday
by WorkonSunday
KCNC make some of their rotors in titanium:
https://www.bike24.com/p257271.html
that will be 20g for the front. dont think they offer 140mm tho.
also RED cassette will also shave some weight over dura ace too
Some say pour 10ml water out of your bottle to save that last bit of the weight. Sorry, i go one step further, i tend to the rider off my bikes. :thumbup:
DanielNorway
by DanielNorway
For comparison, my 56cm weighs about 6.94 kg including:
- Full DA 9170 50/34 11-28 4iiii dual side crank, XTR 160/140 rotors
- PYC 1101 chain
- Speedplays 140g
- Antares saddle 140g
- LB46 wheelset 1390g
- Hutchinson Fusion 25mm 260g x 2 + 2x30ml sealant
- Canyon bartape
- Wahoo mount
- XXX Bontrager bottle cages 2 x 20g(?)
survivor
by survivor
alcatraz wrote:
Tue Nov 12, 2019 4:43 am
Not much choice for the stem if wanted to keep the clean aesthetic of internal cable routing.
chris14
by chris14
Can't wait to see some photos of the beast
Alexandrumarian
by Alexandrumarian
1150g disc clinchers? Are you super light? But first thing id look at the canyon evo. The frameset has been recently listed for sale, 4k, probably about 100g lighter than the bmc.
alanyu
by alanyu
BB: Shimano BB92-41, 54g, and it's much cheaper.
Cassette: ZTTO 11-28T, 177g.
Chain: CP record 11, 240g, or YBN Titanium 11 220g if your pocket is deep enough to replace rapidly.
Tires: Pro one addix 2020 * 2, 520g
Chain Catcher: No need = 0g
survivor
by survivor
Alexandrumarian wrote:
Tue Nov 12, 2019 7:59 pm
I'm not heavy. Partington wheels are listed to be stiffer than Meilenstein and ENVE SES, which I already riden before without issue, so at least on paper there is no flex issue.
Canyon Evo has expose cables. Not the aesthetic I'm looking for. Just personal choice.
tabl10s
by tabl10s
THM Clavicula/Tibia/Extralite rings/Cane Creek AER II. Any combo of all might get you to your goal
2015 Pinarello F8: 13.05lbs/5.915kg
2016 Rca: 11.07lbs/5.048kg
2018 Rca
2018 S-Works SL6 Ultralight: 12.03lbs
