c24 9000 vs rs81 c24
panta
by panta
Hi
Does anyone know if the internal parts of hub of the wh9000 c24 dura ace fit in the rs81 c24 hub shell?
I heard the 9100 model parts do fit, but want to make sure the 9000 ones fit as well. Thanks
Ritxis
by Ritxis
panta wrote:
Fri Nov 08, 2019 9:00 am
Hi
differences in the internal parts are appreciated........incluse te bearing ball are different (number or size)
compare front hubs; 9000 https://si.shimano.com/pdfs/ev/EV-WH-90 ... -3333A.pdf RS81 https://si.shimano.com/pdfs/ev/EV-WH-RS ... -3577A.pdf
Rear; 9000 https://si.shimano.com/pdfs/ev/EV-WH-90 ... -3334A.pdf RS81 https://si.shimano.com/pdfs/ev/EV-WH-RS ... -3578A.pdf
panta
by panta
I am aware the inside parts are different. What I wanted to know is if those internal parts do fit inside the hub shell of the other model. Thanks though
maxxevv
by maxxevv
You just need to replace the bearings on the RS81 with better grade aftermarket ones. And you are done.
Typial RS81 bearings are about Grade 100 steel balls, get something in the Grade 20 or better range. They are relatively inexpensive, but just stay away from the ceramics and stick with steel ones.
