Favero Assioma Duo - Zero offsetting trouble
M4lukz
by M4lukz
Hello everyone, not sure if this is the right place to post this, but here it goes.
I have a pair of assioma duo's pedals, and quite recently, after swapping them from bikes, I haven't been able to perform a "zero offset" from the app, neither from a head unit. Not quite sure what's causing this, the data is everything but accurate, power balance is 100%/0% (L/R) most of the ride, power numbers are <50 most of the times, if I go to sub-50 rpm, the power numbers spike to the 1500-2000 range...
Did something similar happen to anyone here?
kevinw
by kevinw
Never heard of anything like this sorry. I would definitely reach out to favero via their website.
If it looks like the left pedal is working it might be interesting to switch it to "Uno" mode via the app and see if you get accurate results from the left pedal only.
M4lukz
by M4lukz
kevinw wrote:
Mon Nov 04, 2019 3:32 pm
Am I able to convert the left pedal to UNO, and then back to duo? after analising the ride a bit more, I found one or two places where the balance was registering something from the right pedal (even tho it was only for a brief moment)
On3
by On3
The firmware of both pedals is up-to-date?
I met this strange behavior one year ago (after ~8h drive on car roof of a rainy day), and after updating firmware it was possible to zero offset (from head unit and from the app).
M4lukz
by M4lukz
On3 wrote:
Mon Nov 04, 2019 4:20 pm
the pedals are on the last version (v4.04), for some months now... this was a first also... currently waiting on some input from favero themselves
kevinw
by kevinw
M4lukz wrote:
Mon Nov 04, 2019 3:42 pm
Yes you can switch back.
Vuong05
by Vuong05
M4lukz wrote:
Sun Nov 03, 2019 12:28 am
I experienced the exact same thing today mid ride. Pulled over and tried the zero offset the pedals, but had no luck. Did you hear back from Favero regarding this issue? I'm on the lastest version (v4.04) as well.
Up to this point, they have been flawless. I have approximately 7500 km on my Duo pedals if that matters.
Current Stable. Evo (Storm Trooper) : 5.39kg | Alchemy Eros : Heavy (7.25kg)
M4lukz
by M4lukz
Vuong05 wrote:
Mon Nov 11, 2019 10:08 am
I'd recommend you to contact their support. Their replies take usually 1-2 business days, but the support is really good, and really helpful. They'll remotely check the pedal sensors data and try to see if there are any "unusual values". From that point onwards, they'll see what the best option is, and proceed from there.
grymg
by grymg
Interesting issue, I haven't rezeroed mine in ages since they perform fine and I never remove them from my bike. I'll try the next time I ride. Anyways still loving mine.
