SRAM etap front derailleur drifts slowly while riding
It is a SRAM red etap non AXS.
When riding on the big ring, the front derailleur drifts slowly inboard. Not much, something like an half width of the chain, but enough to make the chain to rub on the derailleur when on the 4-5 bigger sprockets.
There is a way of reset its position.
Stop pedalling, shift the derailleur inboard, then immediately outboard( a shift for nothing ).
On a 100km ride, I may have to do it 3-4 times.
Not a big deal but annoying.
Anyone experienced this already or found a solution?
You've adjusted the front screw and it still drifts? https://youtu.be/XlLwu-SDo5w?t=400
Seems like maybe the screw is stripped or loose or something. I have run red eTap for a few years now, and not experienced what you've decribed.
Piling on, but this is the first I’ve heard of FD cage drift. I have multiple sets of eTap and never encountered this.
- Moderator
- Contact:
I think most would consider that a pretty significant annoyance..
Is it still under waranty?
Sent from my SM-G977B using Tapatalk
Using Tapatalk
The limit screws prevent the dérailleur to move inboard too much on the small ring, and too far on the bigger ring. Right?JackRussellRacing wrote: ↑Sat Oct 26, 2019 10:40 pmYou've adjusted the front screw and it still drifts? https://youtu.be/XlLwu-SDo5w?t=400
Here the derailleur moves inboard on the big ring, so I'm not sure it is related to the limit screws.
In fact, yes it sucks.Nefarious86 wrote: ↑Sun Oct 27, 2019 1:20 amI think most would consider that a pretty significant annoyance..
But since there is a workaround, and I'm out of warranty, I got used to it.
It certainly played a role in my move to EPS 12 for my new build.
It always gives you some comfort not being alone
Were you an early buyer?
I got it in may 2017, and if I remember well the etap HRD was not readily available at that time.
Have your reached out to SRAM about it? It may be a known issue that they'd cover under goodwill.carbonazza wrote:In fact, yes it sucks.Nefarious86 wrote: ↑Sun Oct 27, 2019 1:20 amI think most would consider that a pretty significant annoyance..
If you don't ask, you'll never know...
Sent from my Pixel 3 XL using Tapatalk
carbonazza wrote: ↑Sun Oct 27, 2019 9:18 amIt always gives you some comfort not being alone
eTap FDs have been available since late-2015, early-2016. No apparent change was made to the FD when eTap HRD was introduced.
And the outboard limit screw serves as an indexing position as well.carbonazza wrote: The limit screws prevent the dérailleur to move inboard too much on the small ring, and too far on the bigger ring. Right?
If I recall correctly, eTap FD doesn't automatically compensate it's position depending on which sprocket the RD is at. So, there shouldn't be any drift or additional movement involved in normal operation - the FD's cage should be either at the outboard or inboard position.
One thing strictly forbidden in the installation manual is tightening the outboard limit screw while the FD is in the inboard position. If that has happened, I guess something like these symptoms might result from that.
Right indeed... But contacting SRAM directly is like a labyrinth.
I first contacted Canyon who I got the derailleur from and will see what they say.
The derailleur goes a bit farther when shifting up, then comes back in position.Jugi wrote: ↑Sun Oct 27, 2019 12:43 pmIf I recall correctly, eTap FD doesn't automatically compensate it's position depending on which sprocket the RD is at. So, there shouldn't be any drift or additional movement involved in normal operation - the FD's cage should be either at the outboard or inboard position.
And no, it does not compensate from the chain position on the cassette.
I saw the big warning on the setup video. And never did that.
However I had an up-shift issue with this derailleur from the beginning.
The bike went 2-3 times back to Canyon's service.
Unfortunately the derailleur problem got hidden by a crack on the frame at the fixture.
The frame was replaced, giving the impression it was the issue, but no.
Then since I live in the relatively flat Belgium, I ride on the big ring most of the time and got used to the quirk, until I noticed recently the drift.
- Similar Topics
- Replies
- Views
- Last post
- 0 Replies
- 397 Views
Last post by jerbax18
Wed Jan 16, 2019 2:44 pm
Yup... another etap front derailleur thread. Sanity check.
by RocketRacing » Tue May 07, 2019 4:10 am » in Road - 57 Replies
- 4103 Views
Last post by pdlpsher1
Wed Jun 19, 2019 12:54 am
- 45 Replies
- 8174 Views
Last post by Ritxis
Sun Jul 07, 2019 3:10 pm
- 7 Replies
- 606 Views
Last post by RocketRacing
Fri Apr 19, 2019 8:24 pm
- 2 Replies
- 538 Views
Last post by tabl10s
Sun Jun 30, 2019 3:11 pm
