Check out this thread
viewtopic.php?f=3&t=157599
I didn’t like the Hylix as it slipped, I’m 82kg
The Elita One is working well, however, I did need to sand the post so the saddle cradle would properly fit
27.2 seatpost suggestions
Building Spec Allez
Sold
Fuji SL 5.5kg viewtopic.php?f=10&t=157704
Sold -
Izalco Max Disc 6.7kg http://weightweenies.starbike.com/forum ... o+Max+disc
Sold
Sold -
+1 and there is also the WCS Flexlogic one, little bit cheaper for a couple grams more and lighter than the one bolt normally: viewtopic.php?t=128888
Edit: I just received it, 27,2x400 is 172g. According to the thread above, the Superlogic weight 153g for a 27.2x350.
And from an another WCS seatpost, 10cm of 31,6 tube weight 30g, so we could imagine 5cm of 27,2 will be around 13g, so the difference between WCS and Superlogic is around 6g
Edit2: after cutting 10cm of my post 27,2, the weight is 28g, so the difference between WCS and Superlogic is 5g for 350mm lenght.
