spacers for casstte
WorkonSunday
by WorkonSunday
Hi all, abit of a dumb question. if i want to run a 8 speed cassette on a 11 speed freehub (shimano) what spacer do i need? 1.85mm is for 10 speed cassette to 11 speed freehib, do i need to stack more? or there are other ones out there i can use? Thanks. :thumbup:
Some say pour 10ml water out of your bottle to save that last bit of the weight. Sorry, i go one step further, i tend to the rider off my bikes. :thumbup:
shotgun
by shotgun
8/9/10 cassettes have similar widths. So you'll just need a spacer for a 10s, 1.85mm
2018 Giant TCR Advance SL0 Disc
2017 Festka Scalatore
1989 Battaglin Roche
1985 Alan Carbonio
Attermann
by Attermann
shotgun wrote:
Thu Oct 24, 2019 8:40 am
10 speed is 1 mm narrower than 9, so when you put a 10 on an 11 speed body you need a 1 and 1,85 mm spacer.
ricerocket
by ricerocket
Throw it on the freehub and see. If the final cog is flush w/ the freehub (or the freehub is taller), add a spacer so the cassette doesn't wobble. Make sure you torque to the final torque setting before checking.
SRAM 10-spd cassettes are not supposed to require the spacer like the Shimano 10-spds, but in practice, it all depends on the freehub body length.
WorkonSunday
by WorkonSunday
thanks for the replies guys. will give it a go. cheers.
