ryanw wrote: ↑Sat Jan 22, 2022 4:59 pm964g - 61cm - Sagan Disruption
953g - 58cm - Red Tint / Metallic White Silver / Satin Black
931g - 58cm - Blue Tint over Spectraflair / Brushed Chrome
923g - 58cm - Dusty Blue Pearl / Cast Blue Metallic
918g - 58cm - Carbon/Lagoon Blue/Limestone/Gloss Abalone
872g - 58cm - Carbon / Chameleon Silver Green Colour Run
868g - 58cm - SATIN CARBON / SPECTRAFLAIR TINT / GLOSS BRUSHED CHROME
854g - 56cm - Blue Tint over Spectraflair / Brushed Chrome
831g - 54cm - Snake Eye / Satin Black
821g - 56cm - Blue Tint over Spectraflair / Brushed Chrome
811g - 56cm - Sagan Deconstructivism
807g - 56cm - Carbon / Chameleon Silver Green Colour Run
805g - 56cm - Dusty Blue Pearl / Cast Blue Metallic
802g - 56cm - Trinity Team Bike
790g - 56cm - Trinity Team Bike
786g - 56cm - Carbon / Chameleon Silver Green Colour Run
785g - 56cm - Carbon / Chameleon Silver Green Colour Run
784g - 54cm - Dusty Blue Pearl / Cast Blue Metallic
783g - 54cm - Dusty Blue Pearl / Cast Blue Metallic
779g - 54cm - Dusty Blue Pearl / Cast Blue Metallic
773g - 54cm - Dusty Blue Pearl / Cast Blue Metallic
771g - 52cm - Snake Eye / Satin Black
768g - 54cm - Trinity Team Bike
766g - 49cm - Dove Grey
756g - 54cm - Trinity Team Bike
755g - 52cm - Carbon / Chameleon Silver Green Colour Run
748g - 52cm - Trinity Team Bike
727g - 49cm - Trinity Team Bike
721g - 49cm - Carbon / Chameleon Silver Green Colour Run
719g - 49cm - Carbon / Chameleon Silver Green Colour Run
2020 Specialized Tarmac SL7
Just done a video on my instagram showing how to remove these.
As for the lower part being trapped, it's essentially impossible for it to get stuck due to the size of it, unless somehow it's got lodged at the bottom of the steerer (where it meets the fork) and twisted to the side.
Good old fashion brute force should do the trick. Just bang the end of the steerer on a hard surface to hopefully dislodge.
IG: RhinosWorkshop
IG: RhinosWorkshop
Could anyone who's been successfully running the new 12s DA or Ultegra groupset on SL7 share your tips on setting up the front derailluer?
Here's my situation:
Just finished installing R9270 and the front derailleur is sitting too far outboard, I am using stock R9200 crankset.
When setting FD up using the e-tube app assistance, I had to trim the FD all the way inboard to max setting at -19.
Even at this setting there is still a gap of ~2mm between FD outer chain guide plate and the chain when on the large chainring, ideally there should only be 0.5~1mm gap, I couldn't bring it any closer as -19 setting is maxed out, so I canted the guide plate tail inward, but the shifting from small to big is not very smooth, the chain "catches" a bit before climb up to the big chainring.
Seems to me that SL7 FD braze on mount needed an updated for the new FD design?
Is this big/big? No spacer on DS spindle?riochang wrote: ↑Sun Jan 23, 2022 2:33 pmCould anyone who's been successfully running the new 12s DA or Ultegra groupset on SL7 share your tips on setting up the front derailluer?
I've not had a single issue on the 6x 9200 SL7's I've built...
Will check what position is on my perosnal bike shortly.
IG: RhinosWorkshop
IG: RhinosWorkshop
Big/small 50/11, no spacer on DS spindle. Did you also set to -19 setting on the app?ryanw wrote: ↑Sun Jan 23, 2022 3:44 pmIs this big/big? No spacer on DS spindle?riochang wrote: ↑Sun Jan 23, 2022 2:33 pmCould anyone who's been successfully running the new 12s DA or Ultegra groupset on SL7 share your tips on setting up the front derailluer?
Thanks!
Hmmm, now that is interesting! Going for a superlight SL7, Ome? Will you keep your existing SL7 nonetheless?
All this talk about paint weight got me thinking… is this in the usual range for Pro frameset 56cm 974g - white is supposedly the heaviest paint color. - who knows if it came off the assembly line and went in again for a second dousing.
All
All
Couldn't wait for my Dogma F order. It's so difficult to get a frameset nowadays so just got another one that's readily available. Not a superlight SL7, but a 12s version. Keeping the old one too.
The tension. One could cut it with a knife.
'24 S-Works Tarmac SL8 RTP - soon™
'22 Tarmac SL7 Expert | Ultegra R8100 | Alpinist CL / Custom Rapide CLX 2x60
'19 Diverge E5 Comp
'18 Epic HT Comp Carbon WMN
'18 TCR Adv Pro 1 Disc
'19 Diverge E5 Comp
