I've recently switched to the direct mount hanger, it puts the derailleur in exactly the same position, no need to adjust the chain length, I didn't even need to reindex the shifting
2020 Specialized Tarmac SL7
Yes and no adjustments done
Road // 2023 S-Works Tarmac SL8 | Shimano Dura-Ace Di2 | Roval Rapide CLX
Gravel // 2023 Specialized Crux Pro | SRAM Force AXS | Roval Terra CL
Retired // 2022 S-Works Shiv TT // 2021 S-Works Tarmac SL7 // 2019 Specialized Allez Sprint Red Hook
The ones below are what I am using on my SL7's stem bolts. A little weight savings and great finish.
https://www.amazon.com/gp/product/B07BM ... UTF8&psc=1
Had the same issue with a venge.. turned out to be bad headset installation :s
Hi jadeaid,jadedaid wrote:Thanks! Will try to drop Redbeard a line.Fideliojbc wrote: ↑Wed Jun 09, 2021 12:15 amI just bought one. In the NY area there are a few bike shops with frames available.jadedaid wrote:I've been mulling over the idea of the SL7 for some time now. Does anyone have an idea what the wait times currently are for a frame set order in the US?
Enviado desde mi iPhone utilizando Tapatalk
I received your PM but I cannot respond.
There a few Specialized bike shops in the NYC area. Strictly, Roy’s and Hilltop at least have frame sets available. I reached out one of them which has group sets and handlebars as well. Not sure if I can post here which one.
They can't even serve MY21.
They are readily available where I live...
Cervelo P5 Disc (2021) 9.1kg
S-Works SL8 (2023) 6.3kg
Well so it turned out inseam was 83cm ..and i think the size 54 was a good option..got it today and so far i like it a lot! Better then the SL6! Feels way stiffer then the sl6 rim brake version imo.. regarding disc brakes: until now i didnt feel a difference to the rim brake version, so its a weight penalty for nothing (but thats my opinion)
Position feels a little more upright but not bad and still 1 cm of spacers that could be removed..
Hey CtV, what is your BB to saddle top (middle line on saddle) in mm? Thanks!CtV wrote: ↑Thu Jun 17, 2021 9:50 pmWell so it turned out inseam was 83cm ..and i think the size 54 was a good option..got it today and so far i like it a lot! Better then the SL6! Feels way stiffer then the sl6 rim brake version imo.. regarding disc brakes: until now i didnt feel a difference to the rim brake version, so its a weight penalty for nothing (but thats my opinion)
