2020 Specialized Tarmac SL7
cmis
by cmis
tonytourist wrote:
Wed Jan 19, 2022 4:21 pm
Tarmac SL7 52 - Gloss Carbon/Oil Tint/Forest Green
How is the color in real? Still waiting for my 58 to arrive …
Thanks!
dmccombs
by dmccombs
For those that oredered the Shapeways 1030 Garmin Mount that attaches to the from of the Tarmac stem...
Can you tell me where you got the M4 Tee nut, on the backside of the stem plate, that holds the screw,? It looks like this M4 Tee nut must be thin, and possibly curved.
Sanders2177
by Sanders2177
dmccombs wrote:
Fri Jan 21, 2022 2:46 am
Can you not use the one with the Specialized mount?
S Works SL8 54cm 5.94kgs
Winspace SLC M Ultegra R8150 no idea of kgs
dmccombs
by dmccombs
Sanders2177 wrote:
Fri Jan 21, 2022 9:02 am
I don't have the specialized garmin mount. One didnt come with my SL7 Expert.
dmccombs
by dmccombs
LanceLegstrong wrote:
Thu Oct 15, 2020 2:49 pm
What I did was get an M4 nut (https://www.amazon.com/gp/aw/d/B07H57XW ... asin_title) and use a dremel to square it off to fit. Then bought the Shapeways mount (https://www.shapeways.com/product/HYAZA ... =165417997). I didn't weigh it unfortunately before mounting but it looks and feels solid so far. I'll post a picture when I get home.
When you bought that Tee Nut, did you have to dremel the flat base, or the cylinder that retains the screw? And, did you need a vice to hold the nut while you used the dremel, or will a pair of pliers suffice. Sorry for the dumb questions, but I'm not too handy...
OnTheRivet
by OnTheRivet
ryanw wrote:
Wed Jan 19, 2022 10:11 pm
Heavier, more expensive and more brittle.
I'm doing this for function over flare.
Titanium could be heavier (depends on the design) and more expensive but not brittle.
OnTheRivet
by OnTheRivet
Sanders2177 wrote:
Tue Jan 18, 2022 5:45 pm
Hey All
Just purchased a couple of direct mount hangers for Shimano rear derailleur the usual suspect Sigeyi and a brand called Redshift from AliExpress.
Negligible weight difference but does not show on my scales both 12g. Sigey says 12.1g and Redshift 12.5G.
very subtle diffrences in design when compared side by side up close and same material 7075 T6
Sigeyi £34.99 and Redshift £1.47!
Received today after ordering on 30 Dec.
Anyone else purchased same hanger? All good quality wise no snapping or cracking?
I have the Sigeyi one on my Canyon and it legitimatley shifts faster and more precisely. One of the best "low budget" bike purchases I've ever made.
Sanders2177
by Sanders2177
dmccombs wrote:
Fri Jan 21, 2022 3:36 pm
Oh ok hmmm 🤔 well the magcad mount I got came with fixing off eBay
Sanders2177
by Sanders2177
https://www.ebay.co.uk/itm/293969546548 ... SwOEZgDbaO
dmccombs
by dmccombs
Sanders2177 wrote:
Fri Jan 21, 2022 8:53 pm
Thank you for the info. I see this is in the UK. I am in the US. This would end up being pretty expensive since I already have the stem itself on order.
LanceLegstrong
by LanceLegstrong
dmccombs wrote:
Fri Jan 21, 2022 5:16 pm
The flat base. So it goes from being a circle to more of a rectangle. And below you will see my masterpiece of a drawing. The bottom sketch is a view from the bottom. A set of pliers were good enough for me, just went slow. I don't have a vice but I'm sure it would have helped.
Specialized Crux
Velobuild 168
Trek Checkpoint ALR
LanceLegstrong
by LanceLegstrong
Double post
Specialized Crux
Velobuild 168
Trek Checkpoint ALR
dmccombs
by dmccombs
Sat Jan 22, 2022 1:04 am
Great, Thank You. Your picture were worth a 1000 words. LOL
I am suprised the threaded portion didnt need to be cut. The Tee Nut you specified seems to be 7.5mm in total height and the thread portion 6.4mm. I would have thought that a nut that long would protrude into the Magway stem. Anyway, I must be wrong since it worked for you. I appreciate the info. I had no luck finding a tee nut here in town today. 😫
nathanong87
Resident master of GIF
by nathanong87
got this built up this week!
looking forward to riding
ryanw
by ryanw
964g - 61cm - Sagan Disruption
953g - 58cm - Red Tint / Metallic White Silver / Satin Black
931g - 58cm - Blue Tint over Spectraflair / Brushed Chrome
923g - 58cm - Dusty Blue Pearl / Cast Blue Metallic
918g - 58cm - Carbon/Lagoon Blue/Limestone/Gloss Abalone
872g - 58cm - Carbon / Chameleon Silver Green Colour Run
854g - 56cm - Blue Tint over Spectraflair / Brushed Chrome
831g - 54cm - Snake Eye / Satin Black
821g - 56cm - Blue Tint over Spectraflair / Brushed Chrome
811g - 56cm - Sagan Deconstructivism
807g - 56cm - Carbon / Chameleon Silver Green Colour Run
805g - 56cm - Dusty Blue Pearl / Cast Blue Metallic
802g - 56cm - Trinity Team Bike
790g - 56cm - Trinity Team Bike
786g - 56cm - Carbon / Chameleon Silver Green Colour Run
785g - 56cm - Carbon / Chameleon Silver Green Colour Run
784g - 54cm - Dusty Blue Pearl / Cast Blue Metallic
783g - 54cm - Dusty Blue Pearl / Cast Blue Metallic
779g - 54cm - Dusty Blue Pearl / Cast Blue Metallic
773g - 54cm - Dusty Blue Pearl / Cast Blue Metallic
771g - 52cm - Snake Eye / Satin Black
768g - 54cm - Trinity Team Bike
766g - 49cm - Dove Grey
756g - 54cm - Trinity Team Bike
755g - 52cm - Carbon / Chameleon Silver Green Colour Run
748g - 52cm - Trinity Team Bike
727g - 49cm - Trinity Team Bike
721g - 49cm - Carbon / Chameleon Silver Green Colour Run
719g - 49cm - Carbon / Chameleon Silver Green Colour Run
IG: RhinosWorkshop
