tjvirden
by tjvirden on Thu Jun 10, 2021 7:20 pm
Maddie wrote: ↑Thu Jun 10, 2021 9:56 am
I built it myself. I used the standard 0 offset seatpost from Specialized to make a mould of the D shape. The layup pattern is a mix of UD and 3K carbon cloth. Internal bladder is a modified latex tube to provide compaction. I also made the half moon out of carbon (3K only). The rod, both yokes and titanium bolts are from Schmolke. Total weight is 106g.
Lovely work.
Although seatposts can be relatively simple in structure, to make a reasonable one - even 'just' good enough for personal use - is not at all trivial. I can fully understand why you're not keen to make them for anyone else - the hours add up! Out of interest, did you work with prepreg, or some type of wet layup? 106g is not shabby for prepreg, let alone a wet layup.
tiz92
by tiz92 on Fri Jun 11, 2021 6:50 am
Im using a Tarmac Pro SL7 with the stock wheels. It feels a bit wobbly in fast descents and I cant quit push it in the corners as my old bike (Pinarello Gan S 2017). Does someone have the same issue? Or is it just me?
Maddie
by Maddie on Fri Jun 11, 2021 8:00 am
tjvirden wrote: ↑Thu Jun 10, 2021 7:20 pm
Lovely work.
Thanks! I used prepregs here. So much easier to work with. But back when I was racing motorcycles I built carbon parts with wet layups. Fenders, airbox, fairings etc. I experimented a lot with different cloths like kevlar, glass, but also orientation and how many layers etc. A lot broke in the beginning
Right now I'm intrigued by carbon shoes. But that's something for cold winter evenings...
CtV
by CtV on Fri Jun 11, 2021 10:07 am
ryanw wrote: ↑Tue Jun 08, 2021 10:04 pm
872g - 58cm - Carbon / Chameleon Silver Green Colour
854g - 56cm - Blue Tint over Spectraflair / Brushed Chrome
831g - 54cm - Snake Eye / Satin Black
811g - 56cm - Sagan Deconstructivism
805g - 56cm - Dusty Blue Pearl / Cast Blue Metallic
790g - 56cm - Trinity Team Bike
786g - 56cm - Carbon / Chameleon Silver Green Colour Run
784g - 54cm - Dusty Blue Pearl / Cast Blue Metallic
783g - 54cm - Dusty Blue Pearl / Cast Blue Metallic
779g - 54cm - Dusty Blue Pearl / Cast Blue Metallic
773g - 54cm - Dusty Blue Pearl / Cast Blue Metallic
771g - 52cm - Snake Eye / Satin Black
755g - 52cm - Carbon / Chameleon Silver Green Colour Run
721g - 49cm - Carbon / Chameleon Silver Green Colour Run
Does somebody know the weigth of a Tarmac SL7 Expert Light Silver/Smoke Fade/Black Color size 54?
Tonytony
by Tonytony on Fri Jun 11, 2021 12:57 pm
tiz92 wrote: ↑Fri Jun 11, 2021 6:50 am
I'm riding the roval rapide cl on a venge and I find it a very stable wheelset for its depth
thespaniard
by thespaniard on Fri Jun 11, 2021 1:44 pm
macwatt wrote: ↑Wed Jun 09, 2021 10:07 pm
DCcyclist wrote: ↑Mon Jun 07, 2021 4:06 am
macwatt wrote: ↑Sat Jun 05, 2021 6:51 am
Great choice of colours lovely bike
Current weight 7.8 kg with pedals
Waiting for SRAM Red crankset with power meter to arrive
Where did you get this frame? Do they sell it in the US?
Tarmac SL7 Comp 2022 was purchased in the UK but I'm sure is available to purchase in the US
Updated weight with SRAM Red AXS crankset power meter, Specialized S-Works Power Saddle, Silca latex tubes, pedals, bottle cages and garmin mount 7.4KG
Congrats, that looks sick
Did you change the handlebar too?
I'm looking at that specific model, but I know it comes around 8.24kg for size 52 out of the box. I'm guessing putting a decent set of wheels will save around 400g. What was the next part where you saved the most weight? Crankset?
tjvirden
by tjvirden on Fri Jun 11, 2021 4:17 pm
Maddie wrote: ↑Fri Jun 11, 2021 8:00 am
That's about the only downside of prepreg (okay, storage/shelf life too) - difficulty getting small amounts of less common fibre/resin combinations.
In some ways, the very best composites FEA cannot always match what is learned from making parts which fail! Modern engineering software modelling is a marvel, but it can't do everything and is usually limited by the operator anyway
Is the saddle homebrew too?
If seatposts are not straightforward, then shoes......well I don't think I have the energy!
nateners
by nateners on Fri Jun 11, 2021 8:09 pm
I know poeple have mentioned that the gap between the top of the headtube and the lower transition is more noticeable on the SL7 than the SL6, but how does it compare to the Venge. I feel like the gap on the Venge is pretty small in comparison to the SL7 and they are similar designs. Would love to get some expert feedback from owners.
ill principe
by ill principe on Sat Jun 12, 2021 8:13 pm
Maddie wrote: ↑Wed Jun 09, 2021 8:59 pm
For those thinking about stem/handlebar alternatives. Farsports F1:
Great looking bike! It would look even better with all black chainrings. I used acetone to remove the graphics on my Praxis Works Buzz.
CtV
by CtV on Sun Jun 13, 2021 6:56 am
Hello, wanted to ask you for my optimal tarmac sl7 size! Currently im riding the Sl6 in size 52 (im 173 cm in hight and leg inseam of ~82), i like the fit on it but i run the saddle at 72,5 cm hight from the bb abd with as much setback as possible.. i am using a 100mm stem with 3t bars which have a huge 104mm reach, i run it with 1 little spacer prob 2 mm..Sometimes i felt if like the bike was a little too small?! Now being at the shop i got a 54 recomended, also specializeds sizing guide recomends a 54 with 69,5 cm saddle hight.. what shall i do??
milanv
by milanv on Sun Jun 13, 2021 7:44 pm
Tonytony wrote: ↑Fri Jun 11, 2021 12:57 pm
Yes, Roval Rapide CL are great, stiff wheels with good hubs...
zappafile123
by zappafile123 on Mon Jun 14, 2021 12:48 am
ill principe wrote: ↑Sat Jun 12, 2021 8:13 pm
such a nice looking frameeee. I wish they did a rim-brake SL7
FactorOne|SartoSeta|StorckF.3|Enigma EliteHSS|SworksSL6|ColnagoC60/V3Rs|DeRosa Protos|BianchiXR4/2|BMCSLR01 16|Cdale EvoHM|Focus IzMax|RidleyHe SL/SLX|BH Ulight|BassoDiamante|Scapin DyseysS8|TimeRXRS/ZXRS|TCR SL|RidleyNoah|Look585|CerveloS5/S3
FlatlandClimber
by FlatlandClimber on Mon Jun 14, 2021 9:15 am
Any rumors about upcoming MY22 paint schemes?
Cervelo P5 Disc (2021) 9.1kg
S-Works SL8 (2023) 6.3kg
ViperFFM
by ViperFFM on Mon Jun 14, 2021 9:25 pm
CtV wrote: ↑Sun Jun 13, 2021 6:56 am
Id stay with 52 for the SL7. Your inseam to overall height is realtivley normal. If I had the chance to buy my Venge again, Id go 54 insteand of 56 ( Im 180 with 84cm)
The SL7 has a 3mm longer reach and 10mm lower stack than the Sl6; so you'll already have some more adjustemnt there in your favor. 54 would be to strechted out / too short of a stem. I prefer smaller frames and longer stems as this gives me a better control. But thats just me.
carbonLORD wrote: ↑Fri Mar 12, 2021 12:23 am
I'm a CAT 3 Masters racer, not a dentist.
