Does this mean that a SRAM flat mount disc brake will bolt directly to the frame for a rear 140mm rotor? Finalizing my build and the adaptor for the 160 I was going to run is literally the last piece I'm waiting on.
2020 Specialized Tarmac SL7
Someone in this thread has done this, I will be doing the same for the rear.cfrankscid wrote:Does this mean that a SRAM flat mount disc brake will bolt directly to the frame for a rear 140mm rotor? Finalizing my build and the adaptor for the 160 I was going to run is literally the last piece I'm waiting on.
anyone ?
Specialized Tarmac SL7 10r 61cm (Raw Black Carbon) / r9170 Dura-Ace Di2 11sp / Lightbicycle AR46
Cannondale SuperSlice Hi-Mod 58cm (From EF) / r8050 Ultegra Di2 11sp / AeroCoach Ascalon Carbon / AeroCoach AEOX Zephyr
No, just shove it all to the right of the BB (up the downtube).
IG: RhinosWorkshop
IG: RhinosWorkshop
- robbosmans
- Moderator
- Contact:
GCN at it again weighing bikes with bottles, this weeks victim, a 7.8 kg Sworks Tarmac belonging to Sagan
Heres my freshy fresh SW Tarmac SL7 in size 56.
7.16kg with 2 cages and wahoo mount. Couple build highlights and notes:
1) Enve 40cm SES Aero Bar. This bar is fantastic. The fact that the tops are 36cm center to center really makes them super comfy and aero in the tops.
2) SRAM 1x12 set-up, with Force 10-26 cassette (I live in Florida). I could cut some weight with a RED Cassette, will probably do so when I wear this one out.
Full bottles??robbosmans wrote: ↑Fri May 07, 2021 10:25 amGCN at it again weighing bikes with bottles, this weeks victim, a 7.8 kg Sworks Tarmac belonging to Sagan
I wouldn’t be surprised if Sagan had a beefier version of the SL7.spartacus wrote: ↑Fri May 07, 2021 3:39 pmFull bottles??robbosmans wrote: ↑Fri May 07, 2021 10:25 amGCN at it again weighing bikes with bottles, this weeks victim, a 7.8 kg Sworks Tarmac belonging to Sagan
Why is that?
Road // 2023 S-Works Tarmac SL8 | Shimano Dura-Ace Di2 | Roval Rapide CLX
Gravel // 2023 Specialized Crux Pro | SRAM Force AXS | Roval Terra CL
Retired // 2022 S-Works Shiv TT // 2021 S-Works Tarmac SL7 // 2019 Specialized Allez Sprint Red Hook
