Is it one of the 4 worldwide authorized paint shop by Specialized ? Only way to keep lifetime warrantySanders2177 wrote: ↑Thu Jan 06, 2022 6:06 amOh and for anyone who wants to know the frame in 54cm taken back to its bare carbon was 714g. So 74g paint(788g)
The carbon chameleon Cameleon paint with the bare looking finish actually has 4 layers of finishes over the bare carbon itself
Primer
The Colour
And 2 coats lacquer
2020 Specialized Tarmac SL7
No it is not, not fussed about the lifetime warranty myself as will not have it for lifetime. Will likely change it in a couple of years.
Bike is insured if I have any problems.
S Works SL8 54cm 5.94kgs
Winspace SLC M Ultegra R8150 no idea of kgs
Don't want to say to be honest. And Alistair at Fat Creations is great does quality work as had a Felt done a couple of years ago.MrCurrieinahurry wrote: ↑Thu Jan 06, 2022 1:49 pmWho messed up your paintjob originally?
Basso Diamante super record EPS 12
BMC slr01 ultegra Di2
You definitely get what you pay for
Thanks,Sanders2177 wrote: ↑Thu Jan 06, 2022 2:15 pmNo it is not, not fussed about the lifetime warranty myself as will not have it for lifetime. Will likely change it in a couple of years.
Yes I understand. When I do a paint on a new bike, as I normally ride it 2 years, I prefer to work with the eurepean autorized shop. With an older frameset, no problem to make it otherwise.
I also prefer paint shop working without decals under clearcoat. I Know one or 2 painters in Holland or Italy making beatifull bike (also for big pro teams) but using many decals s it is the case with original paints.
Absolutely love that edition. Really loking forward to your pictures. Am actually looking for a complete bike (Tarmac Speed of Light) in 54 or 52 (not entirely sure, because I kind of fall right in the middle of both sizes) atm. Have spoken to 2 bike shops in Germany and both seem unable to source one.mashiehood wrote: ↑Thu Jan 06, 2022 1:39 pmalistair (FC) is a top man, i had my cervelo finished by him last year. My Sl7 Speed of Light frame is due to arrive tomorow, i have all the bits to start the build over the weekend so will post some pictures. A mix of Ax Lightness (bars) THM / Carbon Ti chainset combo and DA 9200 groupset with Enver AR wheels.
ive just installed a C Bear BSA with integrated sleeve - be mindful you will need the 2in1 tool from C Bear as it has only 10 notches!
no idea - didnt look at others as i think C Bear are the only ones who have the sleeve option and I dont want my spondle exposed to potential cable rub!
It isn't. Most have the sleeve.. I have a BBinfinite (Ceramitech version) BSA30 for my rotor 3D+ crankset and it has it. also is very light at only 73g.mashiehood wrote: ↑Mon Jan 10, 2022 10:39 amno idea - didnt look at others as i think C Bear are the only ones who have the sleeve option and I dont want my spondle exposed to potential cable rub!
https://www.bbinfinite.com/products/bsa ... 3975871621
here's the version for shimano cranks (little heavier at about 89g): https://www.bbinfinite.com/products/bsa ... 2656916547
Specialized Tarmac SL7 10r 61cm (Raw Black Carbon) / r9170 Dura-Ace Di2 11sp / Lightbicycle AR46
Cannondale SuperSlice Hi-Mod 58cm (From EF) / r8050 Ultegra Di2 11sp / AeroCoach Ascalon Carbon / AeroCoach AEOX Zephyr
C-Bear BSA 24mm (100gr) is heavier than Shimano Durace 9000 (68gr)
Well here it is just finished it..... spec:
Frameset - SL7 Speed of Light 54cm
Dura Ace Di2 9200 140mm rotors F&R
SL7 stem 100mm with SL& Garmin Mount & SL7 seatpost
THM Clavicula SE chainset with Carbon Ti Chainrings
Berk Saddle
Look Keo Blade Ti Ceramic pedals
AX Lightness Ergo 4200 bars (40cm)
Supacaz Tape
Enve AR 4.5 wheelset with DT Swiss 180 Hubs on Enve tyres (27 front, 29 rear)
Second Wheels are Light Bicycle Falcon Pro 46 (flyweight) with Carbon Ti Hubs with Enve 25c tyres F&R
Weight with Enve Wheels - 6.8kg and 6.5kg with Light Bicycle Wheels
I am one of those off beings that are short (5'8) but with long legs (82 inseam) so sit bang in the middle of a 52/54 framesize. To date i have ridden small but most recently I have been riding a Moots Vamoots in a 54cm and it feels so much nicer than a smaller frame, hence the 54cm for the SL7. First ride tomorow.
Berk Saddle
Supacaz Tape
- MrCurrieinahurry
- Moderator
You did that with spray cans
