i had one of these on order, but the delivery has been cancelled! i had to pick another frame.
2020 Specialized Tarmac SL7
- Maximilian
If anyone in the UK is looking for a built S-Works SL7 or a frameset Mike Vaughan Cycles in Kenilworth have stock.
https://www.instagram.com/mikevaughanc ... =copy_link
I have this frameset on order but I'm a little confused about the name of the white that Specialized uses. Chameleon Silver Green tint over White...what does the white look like in the sun or under a light? Is it just white or does it have some sort of color shift?
Thanks! that's a huge difference to my -19 setting. could you take some picture on how your FD is currently setup? how far outboard is ur FD sitting away from the seattube, and how close is the FD outer plate from chain when in big/small (heaviest gear).
The white is white! with a metallic finishEsotericCyclist wrote: ↑Tue Jan 25, 2022 6:14 pmI have this frameset on order but I'm a little confused about the name of the white that Specialized uses. Chameleon Silver Green tint over White...what does the white look like in the sun or under a light? Is it just white or does it have some sort of color shift?
The box with my Expert (54, Tropical Teal) should arrive on Monday.
I'm from the mainland Europe.
'24 S-Works Tarmac SL8 RTP - soon™
'22 Tarmac SL7 Expert | Ultegra R8100 | Alpinist CL / Custom Rapide CLX 2x60
'19 Diverge E5 Comp
'18 Epic HT Comp Carbon WMN
'18 TCR Adv Pro 1 Disc
'19 Diverge E5 Comp
Currently looking at buying a SL7 frame to build up but wondered does anyone know when the SL8 "could be" released?. I realise the reality of supply will be the same as the SL7 given the worldwide conditions but was curious to see when we would typically see the new iteration. Thanks.
