Is that 1.8mm Lizardskin bartape?
2020 Specialized Tarmac SL7
I ordered a pair of Feder Farsports 45mm FR230 hubs. Weight approximately 1260 grams. Should arrive in approximately 1 week. Are you happy with your wheels? Any issues with the FR230 hubs?
S-Works Tarmac sl7
Ricca Modelo Uno custom Ultegra di2
Look AL 246 Ultegra 6600
BMC Speedfox Sram NX
M4, 7 mm thread length and the head is a 3 mm hex.
'24 S-Works Tarmac SL8 RTP - soon™
'22 Tarmac SL7 Expert | Ultegra R8100 | Alpinist CL / Custom Rapide CLX 2x60
'19 Diverge E5 Comp
'18 Epic HT Comp Carbon WMN
'18 TCR Adv Pro 1 Disc
'19 Diverge E5 Comp
It seems the SL7 in 58 is lower is 11 mm..... compared to the sl6 the headtube is equal. But ween measuring The frames they did not count the headspacer of the sl7 with The frame. That Spacer is 11mmRonin416 wrote: ↑Mon Oct 25, 2021 1:23 amGet a proper bike fit and they’ll tell you your “ideal” frame size. You can decide how aggressive or conservative you want to be.adriant wrote:I trying to check if I can ride on an 58 frame.
I compared my old bike with a new SL7 in size 58
https://www.velogicfit.com/frame-compar ... spacer2=45
It seems the SL7 in 58 is lower is 11 mm. I think that might be manageable by my back.
Could someone with a 58 frame give me some measurement?
I want to know the distance between from axle to the middle of the stem. (with all the spacers under the stem)
And the max length from the middle of bb to the top of the saddle ( on my current bike is 851 mm)
I feel my old bike a bit to long for me, my saddle was all the way to the front and I had a small stem.
I think a smaller frame could fit me better. But I have long legs and small chest.
I'm 193cm tall with 96cm inseam.
Tarmac’s traditionally have tall head-tubes. That frame has to cater to a wide audience. SL7 is probably the most aggressive Tarmac to date.
The SL7 proprietary headset cover and spacer total 17.5mm.
If you're running a non Tarmac SL7 stem, you can subtract 2mm off that since you don't need to use the proprietary spacer, but the different headset cover is slightly higher.
IG: RhinosWorkshop
IG: RhinosWorkshop
What Ceramicspeed bottom bracket should I pick for a Tarmac SL7 with Ultegra crankset?
I am not able to understand the chart CS has in its website.
Thanks in advance
Thanks in advance
Exactly!
Cervelo P5 Disc (2021) 9.1kg
S-Works SL8 (2023) 6.3kg
Thanks!
964g - 61cm - Sagan Disruption
923g - 58cm - Dusty Blue Pearl / Cast Blue Metallic
872g - 58cm - Carbon / Chameleon Silver Green Colour Run
854g - 56cm - Blue Tint over Spectraflair / Brushed Chrome
831g - 54cm - Snake Eye / Satin Black
821g - 56cm - Blue Tint over Spectraflair / Brushed Chrome
811g - 56cm - Sagan Deconstructivism
807g - 56cm - Carbon / Chameleon Silver Green Colour Run
805g - 56cm - Dusty Blue Pearl / Cast Blue Metallic
790g - 56cm - Trinity Team Bike
786g - 56cm - Carbon / Chameleon Silver Green Colour Run
784g - 54cm - Dusty Blue Pearl / Cast Blue Metallic
783g - 54cm - Dusty Blue Pearl / Cast Blue Metallic
779g - 54cm - Dusty Blue Pearl / Cast Blue Metallic
773g - 54cm - Dusty Blue Pearl / Cast Blue Metallic
771g - 52cm - Snake Eye / Satin Black
768g - 54cm - Trinity Team Bike
755g - 52cm - Carbon / Chameleon Silver Green Colour Run
721g - 49cm - Carbon / Chameleon Silver Green Colour Run
719g - 49cm - Carbon / Chameleon Silver Green Colour Run
6.77kg as pictured:
6.77kg as pictured:
IG: RhinosWorkshop
IG: RhinosWorkshop
