2020 Specialized Tarmac SL7
My scale is accurate
So are mine
61cm Satin Carbon / Jet Fuel.
IG: RhinosWorkshop
IG: RhinosWorkshop
Thanks a lot! Are you using some kind of wave washer RO get some preload? Or just tighten it up? No chance to keep the preload adjuster as it gets too tight?kppolich wrote: ↑Sat Jun 04, 2022 5:56 pmI'm running it on my SL7 with the kogel BB.floriansantana wrote: ↑Sat Jun 04, 2022 4:13 pmSorry if this has been discussed before but I couldn’t find anything using the search function.
It seems to be possible to use a SRAM BB30 crankset with BSA30 bottom bracket, as long as it’s the one with removeable spider. Can anyone tell me, what the exact setup would be then? Do I need any spacers? Do I need to remove the preload adjustment ring and replace it with a wave washer?
Please help me out. Thanks in advance!
Drive Side: No spacers
Non-Drive Side: i think I have a 2mm spacer (see pic)
Cannondale SuperSix Evo Disc
Cannondale SystemSix HiMod Disc
@floriansantana
@floriansantana
Here SL7 Frame 10R in tropical teal : 867gr in 54. I find it light for non s-works bike and painted compared to a more raw paint.
Do you know where I can find screw for front derailler hanger ? Because one of them has damage on screw head recess and I don't want to fail to remove it when it tightened
Pictures of my frame here :
Nice weight. I've got the same frame. ^_^
The FD mount comes with the 2 little screws and the whole thing can be ordered through a Specialized dealer:
S201900003
DER MY21 TARMAC SL7 FRONT DERAILLEUR HANGER W/BOLTS
'24 S-Works Tarmac SL8 RTP - soon™
'22 Tarmac SL7 Expert | Ultegra R8100 | Alpinist CL / Custom Rapide CLX 2x60
'19 Diverge E5 Comp
'18 Epic HT Comp Carbon WMN
'18 TCR Adv Pro 1 Disc
'19 Diverge E5 Comp
Ah ! Beautiful colour, but yeah it's blue/green and not everyone's taste
Thanks for reference of hanger. I measured these 2 screws and I think it's M3x10. Ti bolt ordered on AliE
And if it isn't correct size, I will order your ref at my LBS. Thank you !
No preload. It won't fit.floriansantana wrote: ↑Sat Jun 11, 2022 4:34 pmThanks a lot! Are you using some kind of wave washer RO get some preload? Or just tighten it up? No chance to keep the preload adjuster as it gets too tight?kppolich wrote: ↑Sat Jun 04, 2022 5:56 pmI'm running it on my SL7 with the kogel BB.floriansantana wrote: ↑Sat Jun 04, 2022 4:13 pmSorry if this has been discussed before but I couldn’t find anything using the search function.
1 spacer, torque to spec, adjust spacer width as needed.
Is it possible to fit a 30mm tire in the SL7? The specialized website mentions 28mm and bike blogs are saying it has room for 32mm. I'm trying to figure out if I should stick with 28mm or move to 30mm.
yesbikeaddict314 wrote: ↑Tue Jun 14, 2022 1:49 pmIs it possible to fit a 30mm tire in the SL7? The specialized website mentions 28mm and bike blogs are saying it has room for 32mm. I'm trying to figure out if I should stick with 28mm or move to 30mm.
I have GP4000 that measure 31mm and they fit with a lot of room.bikeaddict314 wrote: ↑Tue Jun 14, 2022 1:49 pmIs it possible to fit a 30mm tire in the SL7? The specialized website mentions 28mm and bike blogs are saying it has room for 32mm. I'm trying to figure out if I should stick with 28mm or move to 30mm.
Hello, is it possible to mount the S-Works Power Cranks – Dual-Sided crankset like the sram BB30 crankset?kppolich wrote: ↑Sat Jun 11, 2022 10:26 pmNo preload. It won't fit.floriansantana wrote: ↑Sat Jun 11, 2022 4:34 pmThanks a lot! Are you using some kind of wave washer RO get some preload? Or just tighten it up? No chance to keep the preload adjuster as it gets too tight?kppolich wrote: ↑Sat Jun 04, 2022 5:56 pmI'm running it on my SL7 with the kogel BB.floriansantana wrote: ↑Sat Jun 04, 2022 4:13 pmSorry if this has been discussed before but I couldn’t find anything using the search function.
Hi there,
Looking at buying the S-Works Tarmac stem for a different bike, but I can't find the width/height dimensions of it. I need to see if the stem will work with the cable routing spacer [i.e. be wide enough to cover it, and high enough with the cut steerer tube] on the bike I'd be using it with. Could anybody help with these measurements? Many thanks!!
I don’t think it is, because the spindle of the S-Works crankset is too short.franckydet wrote: ↑Tue Jun 14, 2022 4:54 pmHello, is it possible to mount the S-Works Power Cranks – Dual-Sided crankset like the sram BB30 crankset?kppolich wrote: ↑Sat Jun 11, 2022 10:26 pmNo preload. It won't fit.floriansantana wrote: ↑Sat Jun 11, 2022 4:34 pmThanks a lot! Are you using some kind of wave washer RO get some preload? Or just tighten it up? No chance to keep the preload adjuster as it gets too tight?
@floriansantana
@floriansantana
