difference between campagnolo potenza HO & non HO rim brake
JoO
by JoO
Can someone explain the difference between
Campagnolo potenza HO and non HO for rim brakes?
And are they cross compatible wrt cable pull?
Alexandrumarian
by Alexandrumarian
Cable pull for the derailleurs? yes you can use the ho rear in a rim group. What might not work that great is the crankset, but im not sure on that.
joejack951
by joejack951
'HO' is just a slightly shifted chainline to split the difference between optimum for rim and disc brake frames: https://www.campagnolo.com/WW/en/Compon ... crankset_2
AJS914
by AJS914
No cable pull differences. HO is "hydraulic optimized". In practical terms, an HO rear derailleur may work a little better on a wider rear spacing (135mm QR or 142mm thru axel). The HO crankset has a small difference in chain line to work better with wider rear spacing.
It makes no sense to me why Campagnolo calls mechanical rim brake Potenza ergopower levers "HO".
JoO
by JoO
AJS914 wrote:
Wed Oct 16, 2019 6:22 pm
Indeed. I understand the chainline.
I don’t understand what the change in the ergopowers would be
joejack951
by joejack951
The wider rear spacing of a disc brake frame should not affect the operation of a rear derailleur at all. Everything is offset outward 2.5mm, including the derailleur, making the total distance traveled as well as the distance to the first and last cogs of the cassette identical to a 130mm frame setup. Unless there's some detail I'm missing.
Alexandrumarian
by Alexandrumarian
Ergopowers are totally different. The rim ones pull cable and the disc work with oil.
JoO
by JoO
Alexandrumarian wrote:
Wed Oct 16, 2019 7:46 pm
I am talking about the rim ergos and RDs.
They were made in 2 variants
older "potenza" now discounted
newer "HO Potenza" more expensive (which is a stupid name because they are still for cable rim brakes, not for hydro)
AJS914
by AJS914
It makes no sense. My guess is that Campy just tacked on HO to everything. It's basically a 2018 part versus a 2019 part.
That makes sense so I have no idea why Campy put the HO designation on the rear derailleur.
Alexandrumarian
by Alexandrumarian
OP you are right, they do say HO for the rim ergos. I looked in the pdf catalogue and it says the inner mechanism is modified to work better with the HO crankset. I think they now offer the HO or H11 cranks for both rim and disc, same as the 12speed has a single type of crank. Graeme, any additional info? Thank you!
