Definitely use the oil level tool for filling / bleeding the hydro brake system. Most of the occasions I have seen where people complain of assymmetric pad movement, they've filled or bled the system using some other method.Miller wrote: ↑Tue Oct 15, 2019 12:17 pmThere are very good Campagnolo installation videos on youtube so have a look through those.carbonazza wrote: ↑Mon Oct 14, 2019 3:46 pmI've broken the piggy bank for my new bike 🤩 and need some Campy advice
I build bikes and wheels for the last 5 years for family and friends.
But it is my first campy build. And have some worries:
I've done a couple of their hydro brakes. Hose fastening is straightforward with a nut and olive at the caliper end. I bought the little metal block for setting the correct distance between caliper pistons while filling with mineral oil.
Opinions vary as to whether you need a tool for making/breaking EPS cable plug connections.
UT chainset needs a 10mm hex key.
Olives and barbs are the same as Magura, as is the fluid, so if you struggle to find these items in your market, the Magura items may be a more readily-available alternative.
