THM Calvicula SE Crank vs Dura Ace 9000
eforce123
by eforce123
I ride with Dura ace mechanical and I was curious if I would notice a difference if I switched to Calvicula SE as its almost half the weight? It seems many people on here run the THM crank on all their bikes. Let me know, thanks!
spdntrxi
by spdntrxi
it makes your overall bike lighter... but my legs at the pedels dont feel any different.
tabl10s
by tabl10s
Looks 😎er.
2015 Pinarello F8: 13.13lbs/5.915kg(w/Roval 64's).
2016 Rca: 11.07lbs/5.048kg.
2018 Rca.
2018 S-Works SL6 Ultralight: 12.03lbs.
alcatraz
by alcatraz
Unless you have a frame that supports 6806 bearings going to 30mm spindle like on the thm would be a downgrade.
spdntrxi
by spdntrxi
alcatraz wrote:
Fri Oct 11, 2019 11:47 pm
isn't that BB30 bearing size ? .... which I have used for many years with M3, Classic and now SE cranks... but I just got a BB86 frame that I am using a SE cranks with.. I know not the ideal bb standard for 30mm ID.. but I check it often and so far it's very smooth still.
rollinslow
by rollinslow
FWIW, the main reason I didn't do it is because the Chris King ceramic BB is better than the THM one in my opinion.
Moots Vamoots RSL (2019)-Dura Ace 9100
Cervelo S1 (2010)-Super Record 12 (viewtopic.php?f=10&t=161577)
Kestrel RT700 (2008)-Dura Ace 9000
Mosaic GT-1 (2020)-in build queue
alcatraz
by alcatraz
spdntrxi wrote:
Sat Oct 12, 2019 12:52 am
Lets just say the bearing size of a bb86 shell with 30mm crank is a compromise. Balls and/or races need to be undersized relative to other setups.
spdntrxi
by spdntrxi
alcatraz wrote:
Sat Oct 12, 2019 4:23 am
no doubt... I expect to be replacing them more often.
eforce123
by eforce123
I ride a 2014 Evo hi mod
