New 2015 Giant Propel build - advice
Hi All,
My first post here. I’ve had several Giant TCR advanced SL’s and really loved them. My current TCR is getting a bit older now, and we all know that moment that we start getting aa taste for something new....well I’m there.
I recently bought a 2015 Propel Advaced SL frameset which sat at my LBS. New, spotless and no discs (not into them, sorry). I’m planning to build it up over the winter and I want it Aero&Light.
What I have:
The frameset (+a set of Fouriers) est 1700 grams (size L, btw)
Deep section hand-built carbon wheels (55 mm) with DT Swiss 1580 grams
Planning to get:
Integrated Carbon bars (Canyon) 370 grams
Ultegra R8000 mech 2260 grams (est.)
Fabric Scoop Saddle Titanium 240 grams (est.)
Tires/inner-outer 800 grams (est)
The total comes in at just under 7000 grams, but this may turn out optimistic and go just over when adding the small stuff like cables/bottle cages/Garmin mount/Pedals (Ultegra Carbon btw)
What’s your take? Is there something you would change in this lay-out from my listing above? Looking forward to your ideas! So if you would change components; which would you have instead? (Price, weight)
Thanks!
What I have:
Planning to get:
Thanks!
I’d bin the fourier pads they are not the best(butsince you go carbon you”ll do this anyway)
Why not choose the giant cockpit? It’s a bit less forgiving than the canyon but I like the shape of the bar.
My choice was di-2 which looks a bit cleaner and shifts better compared to mechanical since the cable bends on the propel cause more cable resistance.
Verzonden vanaf mijn iPhone met Tapatalk
Thanks, got Swisstop pads because that is what the wheel builder told me to get. Happy with the Swiss performance on the TCR (ultegra brakes).sharkman wrote: ↑Sun Oct 06, 2019 6:17 pmI’d bin the fourier pads they are not the best(butsince you go carbon you”ll do this anyway)
DI2 or eTap sounds like fun, but another weight penalty...thanks for the hint re cable routing/easier shift
I am thinking the way that tubeless tires seem to be getting better so quickly that I would go for tubeless compatible rims at least. You can always use a tubed tire on a tubeless rim.
- Watch out for the rim widths vs your calipers. These models were a bit finicky. https://www.giant-bicycles.com/_upload_ ... 20Tips.pdf
- I can't comment on the weight of the calipers, but you'll need to add/subtract on your current Ultegra general weight.
2018 Giant TCR Advance SL0 Disc
2017 Festka Scalatore
1989 Battaglin Roche
1985 Alan Carbonio
1985 Alan Carbonio
tubeless for 25mm road tire is a jokemikemelbrooks wrote: ↑Sun Oct 06, 2019 6:55 pmI am thinking the way that tubeless tires seem to be getting better so quickly that I would go for tubeless compatible rims at least. You can always use a tubed tire on a tubeless rim.
Is di2 that much heavier if at all?
Don't forget to subtract the weight of the ultegra brakes from the mechanical groupset as you have fouriers on the propel.
Please explain joke? Never tried tubeless, so no idea. Seems messy when things go wrongChiZ01 wrote: ↑Mon Oct 07, 2019 2:49 amtubeless for 25mm road tire is a jokemikemelbrooks wrote: ↑Sun Oct 06, 2019 6:55 pmI am thinking the way that tubeless tires seem to be getting better so quickly that I would go for tubeless compatible rims at least. You can always use a tubed tire on a tubeless rim.
Always liked the propel. For me though, aesthetically, the downside has always been the cable entry at the top tube for mechanical, very untidy. Not the greatest with the di2 cable entering there either, but a lot better. Would be much better if there was a way for the di2 to enter with the rear brake cable as on the tcr.
25mm = high pressure = sealants would not sealErikvb wrote: ↑Mon Oct 07, 2019 12:46 pmPlease explain joke? Never tried tubeless, so no idea. Seems messy when things go wrongChiZ01 wrote: ↑Mon Oct 07, 2019 2:49 amtubeless for 25mm road tire is a jokemikemelbrooks wrote: ↑Sun Oct 06, 2019 6:55 pmI am thinking the way that tubeless tires seem to be getting better so quickly that I would go for tubeless compatible rims at least. You can always use a tubed tire on a tubeless rim.
Agree, that is the least attractive feature. But after 3 TCRs I wanted to try something different (not even that different, really). Would have another TCR anyday (if in the right colours!)naylor343 wrote: ↑Mon Oct 07, 2019 12:59 pmAlways liked the propel. For me though, aesthetically, the downside has always been the cable entry at the top tube for mechanical, very untidy. Not the greatest with the di2 cable entering there either, but a lot better. Would be much better if there was a way for the di2 to enter with the rear brake cable as on the tcr.
