Installation of Hambini BB
Zorka
by Zorka
Hi, any experiences with hambini one piece bottom brackets?
I´ve just ordered one for Cipollini NK1K BB386 frame, and Hambini says it´s best to use Loctite 641 with activator. Until now I used Morgan Blue Aquaproof paste in all my B-brackets and it works fine without creaking, and I am worried about possible frame damage with Loctite application.
What works best for you?
alcatraz
by alcatraz
641 is a very gentle retaining compound. It's much easier to take apart compared to loctite 609. I wouldn't worry about it. It's good practice to use it.
Also don't disagree with Hambini or he'll call you stupid and give you a ruthless lecture. :lol:
jacobeh
by jacobeh
I have used a Hambini BB without applying anything and I don't have any issues
corky
by corky
jacobeh wrote:
Fri Oct 04, 2019 11:43 am
You will do now..... he’ll be round to rip your head off
Maddie
by Maddie
I have two Hambini BBs, didn't use anything and no worries at all. Hambini himself says that loctite is a bit optional
Gesendet von meinem MAR-LX1A mit Tapatalk
chiumomo
by chiumomo
Hambini's product is always out of stock, all of my bike have bbinfinte as a result. It comes with VibraTite 530 (Locite 609 equivalent?)
No sure if it is ideal but I use it anyway
slashy
by slashy
is he planning to make new stock actually or no one is aware ?
Calnago
by Calnago
I haven’t had any issues using Morgan Blue Aquaproof Paste for pressfit applications either. It is not a retaining compound, but will help prevent corrosion etc. And it is certainly more “adhesive” than regular grease for sure, which I’d never use in a pressfit application. There’s no harm in using it and if it’s creak free, then fine. If not, then you can remove it, clean it up and reinstall using a retaining compound. Installing and removing pressfit BB’s is not something you want to be doing on a repetitive or frequent basis as over time it may cause wear on your frame. The biggest factor as to your success of a PF BB install in my opinion is simply a proper physical install, which means getting both sides installed parallel and aligned with each other and not moving within the shell.
madik
by madik
I only used a little of white Shimano antiseize on my BB86. I had no creaking before so I didn't see the need to use Loctite. It's probably necessary if the BB shell is a bit looser in tolerances or out of them :)
Functionality > Performance > Weight
hambini
by hambini
slashy wrote:
Fri Oct 04, 2019 1:46 pm
The stock is replenished every Sunday, the demand far outweighs my ability to supply so it often ends up sold out by lunchtime. And then out of stock until the following week.
The only way for me to get around this would be to either give up my day job or outsource the manufacturing.
As for the grease. The aim of the game is to stop any potential movement, if you use retaining compound and activator that is what it is designed to do. If you use grease, the movement may still occur but you might not hear it - so the frame is silently being fretted. Additionally most holes are not perfectly round, the retaining compound will bridge the gap with a bond. Grease will fill the gap.
It's up to the end user what they want to do but those are my recommendations.
Hambini
Hambini Aeronautical Engineer, Polluting YouTube since 2016 - views expressed are my own...
Add me ON TWITTER!
Aerodynamic Masterclass in bicycle wheels
I fixed the bottom bracket from hell
Zorka
by Zorka
Thanks for all replies.
I´m not going to disagree with Hambini, he surely knows what he says. Just searching for experiences from other users.
No doubt Hambini makes high quality BB, if I wouldn´t be sure about that I would buy some cheaper solution. But I´m just getting shivers to hear Loctite and Cipollini frame in same sentence :)
But if 641 really won´t hurt the carbon shell I eventually could use it, considering that bearings can be easily changed without removing BB.
@Calnago: Getting this BB installed parallel is not a problem, since it´s one piece design.
Now I´ll have to check tolerances when BB arrives.
Btw. did you notice increased stiffness with Hambini´s BB? Now I´m riding C-Bear ceramic and it´s good, but nothing special.
chiumomo
by chiumomo
hambini wrote:
Fri Oct 04, 2019 3:20 pm
Hambini
Hi Hambini, which retaining compound you recommend on bottom bracket?
Zorka
by Zorka
Hambini recommended Loctite 641 with 7649 activator for my frame.
So finally I decided I´ll follow his recommendation, I found some small bottles on eBay: https://www.ebay.co.uk/sch/i.html?_from ... tpos&gbr=1
Can I be sure it´s genuine Loctite products?
Activator 7649 is required with L641, or can I apply retaining compound without activator?
