Cheap alternative to bar gel tape
Get one of the shoe inserts sold at drugstores and trim it to size, tape underneath regular bar tape. A common brand is dr scholls in the US. The gel pads won’t work cause you’d cut through the gel walls but the foam ones won’t have such problems.
You could always double or triple wrap using the cheaper tapes under it and then the one of your choice at the top.
The Herd
viewtopic.php?f=10&t=149524
Just one idea, haven't tried....
Make mold using cardboard and tape (maybe 3 minutes job...) Buy some silicone (maybe some childrens toy slime/clay might work as well) and put it to mold. Smooth the surface and let it cure.
Trim the silicone plate with scissors or knife to desired shape.
Juha H >> Swim > Bike > Run
Sink sound damping kits have their own adhesive and would be easy to cut to fit.
