Campagnolo 11 speed shifter overhall
brearley
by brearley
Took my 2011 super record shifters off my road bike this year as the ratchet spring wasn't strong enough to hold tension so the mech would ghost shift gradually down to the 11 sprocket.
Rather than throw the groupset has anybody repaired this kind of thing before and what is the process like? Is it just the g spring to replace at the bottom of the bolt which holds the mechanism together?
AJS914
by AJS914
The newer shifters are supposed to be rebuilt with an assembly. I don't think they even sell the small spare parts anymore. Like this:
https://www.ebay.com/itm/Campagnolo-Sup ... 2744929162
DaveS
by DaveS
Be sure that you get the early model, not the 2015+, or it won't shift properly. The newer models pull more cable.
mr_tim
by mr_tim
Try generally cleaning the internal - it gets grimed up inside especially if you've every put lube on the mechanism which will stop it holding in gear fully
In terms of replacement- yeah it's possible and not at all hard to do (vs the 10v which wasn't nice) BUT for the cost of the parts you will likely be able to get a set of low used levers on ebay which would be similar money and less effort.
DaveS
by DaveS
If used levers are purchased, they also need to be pre 2015.
graeme_f_k
Shop Owner / Manufacturer
by graeme_f_k
AJS914 wrote:
Mon Sep 23, 2019 11:40 pm
We have all the small parts on the shelf as individual items at Velotech. It's true that officially they are no longer available from the factory as loose items but we regularly buy and frag lever bodies so that we can continue to provide a full servicing and spare parts service to Campagnolo customers.
If you are in Hull as your signature suggests, , we can send you a pair of compression washers, which are the parts likely to require replacement. Please PM me your postal address if you'd like to do that, or send us the shifter and we will service and test for you.
