TobinHatesYou
by TobinHatesYou on Sun Sep 06, 2020 8:29 am
andriyi1 wrote: ↑Sat Sep 05, 2020 6:37 pm
Hi guys... I’m bringing the issue back again... what is better to use the short or long compression plugs... I would say straight away that a longer one would do a better distribution of loads around the fork and would increase the friction (although penalising the weight). Another question is, would you use carbon compound in order to again increase friction... additionally I’m asking this because of a “tantan (Chinese)” project and I’m concerned about the torques everywhere!!!
Longer is better, with the caveat that there are some less that optimal long designs that don't make as much contact as fully sleeved options. You generally don't need fiber grip as the expanders have textured or knurled surfaces. Make sure you don't overtorque the expander plug because carbon cylinders can't take as much load in expansion as they can in compression.
andriyi1
by andriyi1 on Sun Sep 06, 2020 8:47 am
TobinHatesYou wrote:andriyi1 wrote: ↑Sat Sep 05, 2020 6:37 pm
Thanks for the reply mate... would you recommend any in particular??
Lewn777
by Lewn777 on Sun Sep 06, 2020 10:45 am
Great post. We discussed this on another thread, engineers mostly suggest supporting the bottom bolt with an expander long enough to reach that far, which means use of spacers above the stem should be avoided. Also that some manufacturers that supply very short plugs believe that their steerers are tough enough to withstand those forces, so it is obviously not advisable to switch out a long plug that might of come with your bike for a shorter one.
c60rider
by c60rider on Sun Jan 16, 2022 11:44 pm
musiclover wrote: ↑Sat Jan 15, 2022 5:10 am
Get the Deda one, Colnago is too slipery. May slide right out.
Got Colnago's fitted to all my frames after I first had one with my C60. I won't fit anything else. They've been torqued to the specified amount and never moved once.
mag
by mag on Mon Jan 17, 2022 12:01 am
The Colnago one is fine, no issues with slipping here.
The Deda one is fine as well, but it has slightly larger diameter. Make sure it would fit into your steerer tube (>= 23.5 mm ID) before purchasing it.
musiclover
by musiclover on Mon Jan 17, 2022 2:39 am
c60rider wrote: ↑Sun Jan 16, 2022 11:44 pm
Depends on how smooth the internal surface of the fork is I guess. It slipped multiple times in my Boardman until I got PRO one which looks like Deda. Out of the top of my head I think the recommended torque was 9 Nm which I adhered to.
You lose nothing getting a rougher design with more friction.
I have retired from this forum, not wasting any more time here.
wooger
by wooger on Mon Jan 17, 2022 5:21 pm
Lewn777 wrote: ↑Sun Sep 06, 2020 10:45 am
Not sure that spacers are relevant really - does this not just mean that the expander plug needs to be at the same point the stem is attached? So provided you have or get a long enough bolt to reach and position the expander in the right place, why would spacers above the stem be an issue at all?
DaveS
by DaveS on Mon Jan 17, 2022 6:46 pm
If a short spacer is placed at the bottom of the stem, it leaves the top of the steerer unsupported. My Cinelli expanding plugs have a ledge at the top, so the have to sit on top of the steering tube and then a spacer is needed on top of the stem.
I avoid all of this problem by gluing a thread insert low enough that it supports the bottom of the stem and the rest is filled with solid epoxy, so the top of the steering tube is also supported. Most of my steerers are slammed, but my current ones have 15mm that could be cut off. I most often use a star nut, ground to a diameter just small enough to barely slide into the steerer. Once epoxies in place, I have good support and no chance of slippage.
c60rider
by c60rider on Mon Jan 17, 2022 11:24 pm
musiclover wrote: ↑Mon Jan 17, 2022 2:39 am
Bit of carbon paste certainly can help here. I use it as a routine when I'm tightening things against carbon so maybe that makes the difference.
musiclover
by musiclover on Mon Jan 17, 2022 11:55 pm
c60rider wrote: ↑Mon Jan 17, 2022 11:24 pm
Did not change anything for me.
OlieSimpson
by OlieSimpson on Tue Jan 18, 2022 9:49 am
mag wrote: ↑Mon Jan 17, 2022 12:01 am
Good catch, the ID of my steerer tube is only 21.5mm so the Deda won't work unfortunately.
So...can anyone recomend something similar to the Deda 70mm compression plug that will with a 21.5mm ID steerer tube?
musiclover
by musiclover on Tue Jan 18, 2022 10:18 am
OlieSimpson wrote: ↑Tue Jan 18, 2022 9:49 am
That's what I use.
https://www.pro-bikegear.com/global/acc ... ander-long ps oh sorry it seems that it says "Minimum inner diameter: 23mm" in the description there.
You will need to search for something with your non-standard steering tube.
