Remove "Rotor" logo on carbon chainring
asiantrick
Post by asiantrick »
I've seen a few bikes on instagram with no logo on the Rotor chainring. I always curious how they did it, since I would love to get mine removed as well. Anyone have done it before? Would Acetone work?
jfranci3
Re: Remove "Rotor" logo on carbon chainring
Post by jfranci3 »
N/A
jfranci3
Post by jfranci3 »
Did they just mount it backwards? Otherwise you can wet sand it if acetone doens't work. (clean acetone off right away btw)
NiFTY
Post by NiFTY »
Mounting it backwards would mean all the shifting ramps and pins are on the outside ie it won't shift.
I suspect the logo is under clearcoat. Sand it and re clearcoat
