Ax lightness vial evo seatpost clamp
Froggy81
by Froggy81
Hello everyone, may i know what size is the seatpost clamp for ax lightness vial evo
I understand yuniper make them and its 30mm... are there any cheaper alternative?
Thanks
Des
wheelsONfire
by wheelsONfire
30.0mm is correct even on the latest models.
The later clamp is machined a bit different.
The old generation was same thickness all around and 10mm stack height.
The new is thinner in the middle and a bit thicker at the up/down.
It also have a "lip" at the top, making the clamp flush to the frame seatpost mast.
It also prevents the clamp from sliding down when you're about to torque it.
Stack height is 12mm (8 grams).
These clamps offer stronger clamping force than a carbon dito.
I also have Smud carbon, which is 2 grams lighter.
To be honest, i would recommend either the new from Ax, or an aftermarket in aluminium.
Use carbon paste and maximum 4Nm.
Bikes:
viewtopic.php?f=10&t=156137
Open *UP* (2016.04.14)
Ex bike; Vial EVO D
Froggy81
by Froggy81
Thanks for the reply
Any specific brand i should look for ?
Froggy81
by Froggy81
Thanks
wheelsONfire
by wheelsONfire
Smuds version is actually nicer made than Darimo.
It's also super precise.
Bikes:
Ex bike; Vial EVO D
NiFTY
by NiFTY
I have had a smud for like 4 years for my cannondale evo( also 30mm). It is beautifully made.
PrinceEdward
by PrinceEdward
https://r.tapatalk.com/shareLink/topic? ... source=app
I use tune skyline wurger 31.6, lighter than the new design
我從使用 Tapatalk 的 Pixel 3 XL 發送
