Paint strip frame to save weight?
RocketRacing
by RocketRacing
A sick part of me always wanted to strip my bike (always overridden), but how do they hold up long term? Any discoloration? I know some seem to use wax with uv protecton.
Lucendi wrote:
Sun Sep 15, 2019 9:12 pm
Hi,
I've come to a point where any additional weight saving come at a very expensive price. :/ I've taken my 2012 Cervélo R3 Team from 7,15 to 6,60 kgs simply by changing/upgrading to commonly avalible parts.
I was wondering roughly how much weight could be saved by stripping the frame and fork from paint?
Is it safe to ride a nude carbon bike or will UV-rays negatively affect the carbon and epoxy composite?
Rudi
by Rudi
Lucendi wrote:
Wed Sep 18, 2019 7:14 pm
What would be the best way to do the decals? A stencil and draw in the letters with a marker or to use vinyl?
What kind of clearcoat would you recommend?
You can buy the decals:
https://www.bicyclestickers.co.uk/collections/cervelo
The answer to both questions probably depend on your capabilities. I've sprayed 2 frames, neither particularly well so ended up getting a professional to do it.
Cervelo R3 - 5.4kg viewtopic.php?f=10&t=142420
Lucendi
by Lucendi
About 10hrs in and 50% done.
jorisee01
by jorisee01
Nice!
Verstuurd vanaf mijn SM-G960F met Tapatalk
Lucendi
by Lucendi
18 hrs in and almost finished;
Lucendi
by Lucendi
Removing the paintwork resulted in a weight loss of 156 grams!!
It has a funky metallic sheen just like the graphite tip of a pencil.
Can I claim this is a Weight Weenie-bike now?
Lucendi
by Lucendi
jorisee01 wrote:
Mon Sep 16, 2019 9:51 pm
Maybe this helps
https://r.tapatalk.com/shareLink/topic? ... source=app
Great tip! - I used some 303 and it came out great, giving the entire frame a clean glossy finish! :)
reedplayer
by reedplayer
good work!
4ibanez
by 4ibanez
Nice! I did similar with my Supersix.
I only moved to blades near the end - sanding was very time consuming and messy. When I thought I was done, there were still some patches of black paint (primer?). I did some more fine wet sanding (800-1500) to get rid of those patches and make sure the finish was to my satisfaction.
Just get some nice decals, unless you want to send your bike away for painting.
jorisee01
by jorisee01
Nice work!
rlanger
by rlanger
Wow, I'd really love to do this. I've got 10 days coming up when I will be unable to ride my bike so it's a perfect time.
Just worried that I'll totally screw it up. I'm not the handiest of handies. :?
Lucendi
by Lucendi
rlanger wrote:
Thu Oct 03, 2019 10:47 pm
If I could do it using nothing but a folding knife, I think you can too!
The paint is soft and the carbon epoxy composite is hard, so scraping the paint off is surprisingly easy.
RussellS
by RussellS
Lucendi wrote:
Sat Sep 21, 2019 9:22 pm
6.5 kg. 14.3 pounds. Yes. You're illegal according to the UCI.
Lucendi
by Lucendi
RussellS wrote:
Fri Oct 04, 2019 8:16 pm
rlanger
by rlanger
Lucendi wrote:
Fri Oct 04, 2019 7:35 pm
The part that scares me a little is tearing down all the components then reassembling. :shock:
