Custom Uno faceplate?
BmanX
by BmanX
Looking for someone that can maybe make a custom faceplate for a Uno stem. Any thoughts?
BIG DADDY B FLOW
AERO & LIGHT is RIGHT
Cervelo SLC 5960g/13.13 lbs
BmanX
by BmanX
Should have been more clear. I want some to make one to my specs!
BIG DADDY B FLOW
Klaster_1
by Klaster_1
BmanX wrote:
Sun Sep 15, 2019 9:22 pm
You can try that yourself. Learn how to use a CAD suite of your choice (I used FreeCAD), 3D-print prototypes to check the fit, CNC and anodize at any local shop.
eric01
by eric01
Wait a second. 4 bolt stems have the same vertical bolt height? That’s the only way that this part can claim to fit many stems... mind blown!
alanyu
by alanyu
eric01 wrote:
Mon Sep 16, 2019 12:38 pm
Maybe the hole is 0.Xmm larger to have tolerance. Not sure about that. In my experience, Deda superleggera's front plate can be used on S-works SL.
Hexsense
by Hexsense
Look at the 4th picture and later. The bolt holes are ovalized to allow different vertical bolt height.
