Dogma disc...head scratcher
Lewn777
by Lewn777
Eliminate seatpost/saddle by standing up - does it still make the noise?
I doubt BB after 4 months with threaded BB.
How about:
-old chain?
-out of alighment RD?
-jockey wheel bearing randomly died?
-loose free hub/free hub has too much play/not properly tightened freehub?
-cleats?
-dirty dropouts?
morrisond
by morrisond
What about your pedals? Lube the springs and make sure there is tension in them.
That has been it for me a few times.
ChiZ01
by ChiZ01
check your rear wheel spoke tension
sfo423
by sfo423
I pulled the hanger; clean & re-lube
I pulled both rear dropouts; clean & re-lube
I pulled the der; cleaned bolt, re-bube
Tightened cassette (was tight)
Its 90% better now. When looking at the shifting, I can see that on some of the cogs the back spin can get 'crunchy.' I'll play a bit more w/micro-shift when I have time. But, it does shift well (that was never the issue, but seems that it is a contributor to the sounds).
parajba
by parajba
Out of the saddle only?
Check that the FD is not touching the big chainring (not the chain, but the chainring). Sometimes it’s mounted a tad too low.
sfo423
by sfo423
FD is clear. Speaking of the FD, I'm yet to throw a chain w/eTap. Maybe I should buy a lottery ticket?
parajba wrote:
Fri Sep 13, 2019 12:32 pm
wilwil
by wilwil
Not familiar with Dogma set post clamp but if its anything like a C64 you might need carbon assembly paste on the seat post. My seat post clicked with every revolution when Im seated.
