Valve extender in carbon rim
How does on remove it without cutting the rim, or punching their fist through the nearest wall?
It went in from the bottom and then got stuck? It seems like you would need to tap it back out the way it went in.
I'm not sure I'm reading the problem correctly?
You have a valve extender roaming around inside a carbon rim ?
You'll probably need 2 people. one to hold the wheel up and get the extender to go down around the valve hole.
Then from below use a needle nose pliers (from the tire/rim side) to try and grab it then a spoke (from the spoke/hub side) [ or long thin rod or some type like a metal coat hanger straight part] to try and get it vertical to get it out.
One trick, if the needle nose is really thin you can get it inside the extender and open the pliers to grip it from the inside. Then you'll have more control. The whole (or hole) trick is how much space you have (tubular vs clincher rim walls) and how deep a profile, etc.
Maybe a magnet would help ?
Cyclocross, in general, is about riding the wrong bike for the conditions.
I don't think so, it is aluminium not steel..
But with enough patience it is possible to manage it. Two people are better. Put the wheel on the table so it is more stabile and you can do very small moves with it. You can't hold it in hands above you unless you can really control your hands like a chinese kung fu master..Get the extender close to valve hole and than use spoke.
....or a 1.5mm Hex key - the bent end comes in handyhannawald wrote: ↑Mon Sep 09, 2019 9:58 pmI don't think so, it is aluminium not steel..
- wheelbuilder
lol Shake it for 3.7 hours without a break. I guarantee that within that time frame everything will line up perfectly and it will fall out.
had it happen twice. be patient. there’s a great youtube video on it. search, watch, do the same.
... dont forget to record it and put it up on youtube, for educational purposes.wheelbuilder wrote: ↑Tue Sep 10, 2019 1:29 amlol Shake it for 3.7 hours without a break. I guarantee that within that time frame everything will line up perfectly and it will fall out.
I guess my reply did not work. I got the wheel horizontal. Put a led flashlight in the hole on the hub side of the rim, and finessed the valve extender into sight, then speared it with a unwound safety pin. Once skewered, i finessed it out the hole on the rim tape end.
I also swore up and down at first. It took about 15 minutes and was a 7/10 on the rage scale.... mainly because it was a new bike day and the second ride on the bike was delayed due to this.
In orher news, the extender messes with my pump accuracy (the valve is part of the original stem, and the extender is a neck that extends up). A traditional valve extender with the actual valve at the top will be going on both wheels asap.
I do not like the extenders that you do not remove the valve core and put on the extender.RocketRacing wrote: ↑Wed Sep 11, 2019 1:08 amI guess my reply did not work. I got the wheel horizontal. Put a led flashlight in the hole on the hub side of the rim, and finessed the valve extender into sight, then speared it with a unwound safety pin. Once skewered, i finessed it out the hole on the rim tape end.
I've found while riding, the ones that I had, the valve would tighten while riding on Vittoria Corsa 3s. I had to use a thin rubber "pipe" to put in the open extender to reopen the valve nearly each and every time before pumping the tires up.
I had some old Spinergy extenders with the top valve that actually pressed against the real valve and you were able to open/close them. That was good until I bought some Continental valve extenders where you move the valve core to the extender. A much better solution overall.
Good to hear you got that extender out of your rim.
Yup, the valve extenders are going. I want accurate pressures and no fuss, and i like my valve where i can see it.CrankyCarbon wrote: ↑Wed Sep 11, 2019 3:22 pmI do not like the extenders that you do not remove the valve core and put on the extender.
