Turbo Cotton vs GP5000 TL on Roval CLX64
Kvnmil13
by Kvnmil13
I am running a set of Roval CLX64 wheels on my Venge. I currently running a 23mm Cont. GP4000 on the front. From a speed perspective (aero and rolling resistance) which tire would be the fastest for the front?
24mm Turbo Cotton with a latex tube
25mm Continental GP5000 TL
23mm Continental GP4000 II with latex tube (current)
Squashednuts
by Squashednuts
You can check out rolling resistance on this site
https://www.bicyclerollingresistance.com/
Fuji SL 5.5kg tubs/5.9kg viewtopic.php?f=10&t=157704
Sold -
Focus Izalco Max Disc - Final Weight 6.7kg - http://weightweenies.starbike.com/forum ... o+Max+disc
Marin
by Marin
How wide are the rims at the brake track, and what's the internal width? You want the tire to be narrower than the brake track for best aero.
welchy
by welchy
Squashednuts wrote:
Mon Sep 02, 2019 9:29 am
This should be your reference for sure.. I use 28MM Turbo Cottons, from a ride persepctive very very good..
cpark
by cpark
Kvnmil13 wrote:
Mon Sep 02, 2019 2:10 am
For a fastest set up, I would use Turbo Cotton 24mm on the front and 26mm on the rear with latex tube.
For a fast set up with a little more punture resistence, I would run GP 5000 25mm on the front and 28mm on the rear.
refthimos
by refthimos
cpark wrote:
Mon Oct 07, 2019 1:22 am
What makes you think the Turbo Cotton is faster than the 5000 TL?
EVO1 | 5.37kg
EVO3 | 6.51kg
SystemSix | 8.01kg
P5 | 9070 Di2 | SISL2 SRM | Enve 7.8/FFWD Falcon | Roval 321
T1 | P2Max Type S | Rolf Prima FX58/Zipp Super 9 Disc
spdntrxi
by spdntrxi
I'm thinking the 23 GP4000 will end up being the same as a 25 5000TL aero/width wise.. so go with a 25 5000TL.
alanyu
by alanyu
5000TL is faster than 5000, and 5000 is faster than turbo cotton.
https://www.bicyclerollingresistance.co ... ke-reviews
spdntrxi wrote:
Mon Oct 07, 2019 4:01 am
GP5000 25c is more aero than GP4000 23c though they are at a very similar width on the wheel.
https://www.aero-coach.co.uk/gp-5000-data
Imaking20
by Imaking20
The question isnt just about crr though. People have gotten so obsessed with BRR results now that they seem to be forgetting how many watts can be given back through a bad tire:rim interface.
BRR is definitely one of your key resources - this series is the other
http://bikeblather.blogspot.com/2015/10 ... 1.html?m=1
Edit: I would definitely not make the claim that a 25mm 5000 is faster than a 23mm 4000 in the wind tunnel based off a test on a single, shallow alloy wheel...
My choice would be the Turbo Cotton or maybe a 5000 with latex. I expect the former to ride and handle a lot better, as well as have the lower cda, the latter will probably have the lowest crr
Current:
Acid Mint Tarmac
Hakka MX
Retired:
Boone |Wilier Wonka|The Dentist|The Bucket List|Specialissima|Evo|T2|Blue|Project C6.0 | elt AR FRD|Colnago C59|S-Works Tarmac SL4|S-Works Venge|Wilier Cento1 SL|Tarmac SL2
