Pinarello f12 Sizing Anomaly
sethjs
by sethjs
I've been thinking about getting an F12. When I run my current bike (Specialized Venge) through bikegeo.net, inputting top tube, head tube, angles, etc, the calculator spits out the stack and reach that Specialized indicate.
But when I input the data for an F12 (in a 51.5), the stack and reach are way off what Pinarello indicate.
Short of getting my hands on the bike itself, any ideas? More likely Pinarello have misstated one of the individual components (the HT length looks very short) or more likely their stack/reach are off?
Thanks!
mf22433
by mf22433
Although I have not checked the Pinarello in size 51.5, I have an F8 size 55 (same geometry to the F10 and F12) and I am currently looking at the Venge. I compared both with Bikegeocalc.com.
Clearly the Venge is longer than the Pinarello (more reach for equivalent stack). You can see on the following link the F8 size 55 compared to a Venge size 56 (used Shadow Bike ans Swap Bikes button to switch from one to the other).
https://www.bikegeocalc.com/#8Venge+56a ... 175G30H30Z
wheelsONfire
by wheelsONfire
mf22433 wrote:
Sun Sep 01, 2019 10:13 am
Last edited by wheelsONfire on Sun Sep 01, 2019 11:07 am, edited 2 times in total.
Bikes:
viewtopic.php?f=10&t=156137
Open *UP* (2016.04.14)
Ex bike; Vial EVO D
wheelsONfire
by wheelsONfire
sethjs wrote:
Sun Sep 01, 2019 12:29 am
Thanks!
I checked your statement to satisfy my curiousity!
I agree, that's so badly off!!
My Ax Lightness Vial EVO Race is 3mm off in stack and 2mm off in reach.
However, Ax sold their bikes with both 3T Rigida LTD (lenght 376mm/ rake 46) and THM CT (Lenght 372mm/ rake 45)
What we need to insert to get true stack at it's best, is each manufacturers headset top cover / dust cap, that covers the upper bearing.
These "caps" can vary quite alot. Ax uses a 5mm version.
If your frame uses a really long dust cap, you can highten stack up to 20mm.
Bikes:
Ex bike; Vial EVO D
sethjs
by sethjs
I believe stack and reach are supposed to be to frame without top cap. That said, the top cap on the f12 is 2cm. So I tried inputting that. Still way off.
wheelsONfire
by wheelsONfire
sethjs wrote:
Mon Sep 02, 2019 5:01 am
Yes, it's supposed to. Asked Canyon and their top cap (according to them) is/ was 27.5mm!!
Bikes:
Ex bike; Vial EVO D
sethjs
by sethjs
Whoa - when I see the 27.5 on the Canyon fit site, I assume that's how many spacers it ships with. The topcap alone is 2.75?
MayhemSWE
by MayhemSWE
wheelsONfire wrote:
Mon Sep 02, 2019 1:43 pm
Sounds more like they didn't understand your question. Canyon's road bikes ship with the steerer cut for 27.5 mm of spacers. The standard headset dust cover for bikes shipping with a one-piece cockpit is about 13 mm tall, while the optional low profile cover is maybe 4 mm.
wheelsONfire
by wheelsONfire
MayhemSWE wrote:
Mon Sep 02, 2019 4:03 pm
Yes, it seems more resonable.
However, i asked how high the headset cover is. They told me 27.5mm.
I thought it seemed off :noidea:
Bikes:
Ex bike; Vial EVO D
fogman
by fogman
@sethjs. What stack and reach did you get for the size 51.5 F12 when you imputed the data?
It's all downhill from here, except for the uphills.
dannywin42
by dannywin42
I had the same issue when trying to put my 54cm scott foil in, one of the dimensions wouldnt work. D
Thankfully just from looking at the numbers between the foil and the new addict I could see that the sizing hadn't changed and I've just been to physically check how much I need to chop the steerer by to make it the same as the foil with the same amount of drop. Luckily for the aesthetics gods it means it will be slammed
Sent from my SM-G975F using Tapatalk
Ringo
by Ringo
I was looking too for a f12.
When I compare it with the 54 sloping colnago, I couldn’t reach a decision.
I know that f12 is lower and longer but sizing of pinarello is a little confusing.
For me it’s not about stack. It’s the reach that I worry more. Any suggestions?
silvalis
by silvalis
Ringo wrote:
Fri Jan 17, 2020 9:40 am
Any suggestions?
stop using geometrygeeks and start plugging the numbers into bikegeocalc. Add/remove spacers and change the stem lengths to understand the difference in reach/stack/hta
ps: the reach sizing is likely not changing linearly to what you expect due to ett because the STA and/or HTA is changing.
Chasse patate
wheelsONfire
by wheelsONfire
I am recommended 52S in Colnago and 55 Pinarello. I am 182cm.
Bikes:
Ex bike; Vial EVO D
Ringo
by Ringo
@ Silvalis: I have no spacers on my 54s. Ok I’ll try the bikegeocalc.
@wheelonfire I’m 1.85m.
I’m fitness flexible and athletic but no way “race flexible”
