GothicCastle
by GothicCastle on Sun Aug 25, 2019 10:08 pm
Not really a weight weenie concern, but thought I'd tap into the forum's vast collective wisdom.
Was just rinsing off a bike and this fell off. It is flexible rubber. Fingers shown for scale. It is split, but I suspect it wasn't supposed to be (and why it fell off something). I was thinking that it might have been sealing housing somewhere, but I don't remember doing that when I put the bike together.
Any ideas?
The bike is a Cinelli Nemo Tig
- Dura Ace 9100
Reynolds wheels
Zipp cockpit / post
GothicCastle on Mon Aug 26, 2019 1:55 am, edited 1 time in total.
Calnago
- In Memoriam
by Calnago on Sun Aug 25, 2019 11:07 pm
You don’t have newish Campy wheels by chance do you? They use those o-rings in the little valve nuts that screw on to their valve extenders. They fit into a little groove of the nut but they don’t come already installed in that groove. I’ve seen some wheels where the person didn’t know where they were supposed to go and just placed them between the nut and the rim itself. If yours was like that I could easily see it breaking and falling off. If so, you’ve possibly got a valve extender that may be clanging against the rim. I’ve also seen them used around brake housings or derailleur housings just to help keep the entire housing from rubbing on the paint. Does the same thing as the rubber “bumpers” that you used to fit on derailleur/brake cables that weren’t enclosed in housing as they were externally routed between stops on the frame. Or, it could be from something completely different but without seeing your bike those would be my two first guesses.
spdntrxi
by spdntrxi on Sun Aug 25, 2019 11:44 pm
TobinHatesYou wrote: ↑Sun Aug 25, 2019 11:21 pm
Or if he were running tubeless, sometimes there's an o-ring under the valve nut
this gets my vote if tubeless
2024 BMC TeamMachine R
2018 BMC TImeMachine Road
2002 Moots Compact-SL
2023 Pivot E-Vault
GothicCastle
by GothicCastle on Mon Aug 26, 2019 1:23 am
These are all excellent guesses.
I had thought about a bottle cage nut, as well. This bike has supacaz fly cages on it, but I don't remember a grommit coming with them or the stock Cinelli bolts.
The bike isn't tubeless; GP 4000's with latex tubes (no extenders). The wheels are older Reynolds Assaults. I do have the Silca Speed Shields on these wheels; maybe it was on one of these.
It is entirely possible that it was on the valve and that I didn't notice it.
Alex2012
spdntrxi
by spdntrxi on Mon Aug 26, 2019 1:50 am
GothicCastle wrote: ↑Mon Aug 26, 2019 1:23 am
did you buy just the shields or the kit... because that is designed with tubeless in mind.. so you might not use the valves... but didn't notice the oring was still in there.
2023 Pivot E-Vault
GothicCastle
by GothicCastle on Mon Aug 26, 2019 1:55 am
spdntrxi wrote: ↑Mon Aug 26, 2019 1:50 am
Just the shields. I'm not confident in these rims running tubeless.
