Road Boost 12x110 (110x12) and Hybrid Road 12x148 (148x12) from DT, Novatec, Shimano
ooo
by ooo
Novatec hubs from 2021 catalog (published 2019.08.23):
12x110 (centerlock) D411CB-CL-B12
12x110 (centerlock) D791SB-CL-B12
12x110 (6-bolt) D791SB-B12
12x148 (centerlock) D412CB-CL-B12-11S
12x148 (centerlock) D792SB-CL-B12-S4S-11S
12x148 (6-bolt) D792SB-B12-S4S-11S
Shimano parts for road boost:
GRX front derailleur chainline=46 (FD-RX400, FD-RX810, FD-RX815)
GRX double cranks chainline=46.9 q-factor=151 (FC-RX600, FC-RX810)
GRX single cranks chainline=49.7 q-factor=151 (FC-RX600, FC-RX810)
spdntrxi
by spdntrxi
I dont like the idea of road boost personally... I hope it does not catch on.
ooo
by ooo
so far, only 2 brands:
Focus Paralane² 6.6 COMMUTE
Focus Paralane² 6.7
Focus Paralane² 6.8 GC
Focus Paralane² 6.9
Focus Paralane² 9.5
Focus Paralane² 9.6 GC
Focus Paralane² 9.7
Focus Paralane² 9.8
Focus Paralane² 9.9
"Thanks to our revolutionary Road Boost Standard with its broad 148 and 110 mm R.A.T. Our axles guarantee an optimal chain line for racinge bikes and therefore an optimal shifting function and less wear."
Specialized Turbo Creo SL Comp Carbon
Specialized Turbo Creo SL Comp Carbon EVO
Specialized Turbo Creo SL Expert
Specialized Turbo Creo SL Expert EVO
Specialized S-Works Turbo Creo SL
Specialized S-Works Turbo Creo SL Founder's Edition
"Future Shock 2.0 w/ Damper, Smooth Boot, Boost™ 12x110mm thru-axle, flat-mount disc"
"FACT 11r carbon, Open Road Geometry, front/rear thru-axles, fully integrated down tube battery, internal cable routing, fender/rack mounts, Boost™ 12x148mm"
TobinHatesYou
by TobinHatesYou
spdntrxi wrote:
Sun Aug 25, 2019 1:38 am
We all knew it was coming. Also another reason for Trek to quickly ditch BB90 on all road bikes since it's easier to mess with chainlines up front without using offset rings or specially stanced cranks.
What don't you like about it besides backward compatibility issues?
spdntrxi
by spdntrxi
mainly backwards compatibility.. having just went full disctard... I'm done "sidegrading" for now.
NickJHP
by NickJHP
TobinHatesYou wrote:
Sun Aug 25, 2019 2:01 am
From my point of view, there are two reasons I don't like it:
1. Higher Q factor
2. I ride heels-in toes-out, and increasing the rear spacing makes it more likely that my heels hit the chainstays when pedalling. Even with 130mm rear spacing, I've encountered some frames with breezer dropouts that I can't ride because of this problem, particularly ones with short chainstays.
TobinHatesYou
by TobinHatesYou
NickJHP wrote:
Sun Aug 25, 2019 6:51 am
1. Higher Q factor
This is usually caused by excessive pronation. Have you considered correcting this with more supportive orthotics?
corky
by corky
Sun Aug 25, 2019 7:03 am
1. Higher Q factor
What other body parts should we be modifying in order to accommodate another industry standard.?.......
TobinHatesYou
by TobinHatesYou
corky wrote:
Sun Aug 25, 2019 7:21 am
This isn’t about accommodating anything but his own physiology. Presumably he doesn’t walk duck-footed. He also runs into issues with some 130mm spaced bikes, but acknowledging that doesn’t fit your narrative. Now I don’t think road Boost will necessarily make it to performance road bikes, but if it does go that far it will be accompanied by a widening at the BB too. If 5mm of additional stance-width is something you can’t deal with, then 135mm (142mm) OLD options will continue to exist indefinitely.
Fitters usually say narrow stance-width isn’t that important and that many people would actually benefit biomechanically from increasing theirs.
NickJHP
by NickJHP
1. Higher Q factor
I've been using custom orthotics in cycling shoes for more than 40 years...
TobinHatesYou
by TobinHatesYou
Oh well then. If you don’t think you can fix it after 40 years, then whatever. Just keep in mind that the vast majority of cyclists don’t have your idiosyncratic pedal stance.
NickJHP
by NickJHP
Sun Aug 25, 2019 10:03 am
Good for them...
XCProMD
by XCProMD
I want to see how boost performers in a wind tunnel, all else being equal.
*I’m being sarcastic
Skickat från min iPhone med Tapatalk
eric01
by eric01
Do you have a link to the whole catalog
Calnago
by Calnago
XCProMD wrote:I want to see how boost performers in a wind tunnel, all else being equal.
Ha! That you even feel that a footnote explaining you’re being sarcastic may be necessary for some is indicative of just how ridiculous things have become in the industry. Image
