Berk Lupina saddle sizes?
Lucendi
by Lucendi
Should I choose the 132 or 150 mm Berk Lupina (unpadded) saddle?
I've ridden the Specialized Romin in the 143 mm size for the past couple of years and have always found the fit good.
Is there a way to tell which size in Berk this translates to?
marcelflash
by marcelflash
First we need to know what your sitbone distance is. Maybe the old saddle was small to begin with. I rode the Toupe 143 and went to Berk 150.
kytyree
by kytyree
That was one of the reasons I went with a padded Lupina, just a little additional width. Continues to be my favorite saddle, I do wonder if I'd get on as well with the 132 unpadded.
cerro
by cerro
Like said before, depends on your sitbones. I used a Specialized Toupe 143mm but got 95mm between my sitbones so more happy with a 132mm Lupina. Best saddle I've had.
/jonas l
Lucendi
by Lucendi
Thanks for all the quick replies!
I'm gonna try the 132 mm and see how it goes.
I'll report back. :)
zinedrei
by zinedrei
is there any significant issue if i use a saddle wider than my sitbone width?
when i had my fit, the fitter didn't have the tool to measure my sitbones and just asked me to try on a Romin.
but it's just a short period and im not sure if that saddle is actually ok for me.
i use an smp well now and i feel numbness so im looking for a better option
galr1
by galr1
I've got a padded lupina in 150, if you want any specific measurements just let me know and I can post them up tonight.
It's a lovely saddle so hopefully works for you.
addictR1
by addictR1
I’ve actually had the same question and ride the same romin saddle in 143. Went to Berks FB page and asked the question. They suggested 150mm for the padded version.
Squashednuts
by Squashednuts
I rode a 143 Toupe
Now use a 150mm Padded Lupina
Like them both Lupina is lighter and feels a little more flexible
Fuji SL 5.5kg tubs/5.9kg viewtopic.php?f=10&t=157704
Sold -
Focus Izalco Max Disc - Final Weight 6.7kg - http://weightweenies.starbike.com/forum ... o+Max+disc
Juanmoretime
Administrator
by Juanmoretime
Went from many years, since 2006 until last year, on a AX Lightness Sprint, 126mm to a Lupina 132mm. While the Sprint for many years was comfortable the Lupina just disappears benith me.
RESIDENT GRUMPY OLD MAN.
kytyree
by kytyree
I rode for years mostly on San Marco Regals and those are pretty wide, loved them. But a padded narrow Lupina is my favorite now.
cerro
by cerro
zinedrei wrote:
Fri Aug 23, 2019 4:38 am
If you got a too wide saddle you sit further forward and not on the supposed place so are sliding forward.
/jonas l
Lucendi
by Lucendi
So after the first ride with the Lupina the first impressions are;
1) It feels a bit stiffer than the Romin S-works, and bumps in the road are more noticable. However, this might improve after a few rides. It might also be due to the fact that it has no padding. I doesn't transfer road vibrations more though.
2) The saddle rails are 7x9, but it doesn't fit the side clamp style S-works seatpost very well. I've got a different style seatpost on it's way, so this doesn't bother me, but maybe this will be important for some people.
3) The Romin has a much more pronounced divot where your ass falls perfectly into place each time you're out of the saddle and you feel very secure. With the Lupina, it takes a bit of sliding back and forward to find the divot.
4) Size wise, the 132mm doesn't seem much different than the Romin 143. I would like to try the 150mm as well to say for sure.
Lucendi
by Lucendi
I weighed the saddle and was kinda surprised by the difference in the stated weight and the weight I measured on my kitchen scale.
It is listed at 75 grams, and came in at 84 grams, so it came in 12% heavier which to me seems significant. :(
Is this an acceptable difference?
