2020 Easton EC90SL carbon crank
cnynrpr
by cnynrpr
ChiZ01 wrote:
Thu Aug 22, 2019 3:14 am
cane creek crank preloader is a work of art should be included on all 30mm cranks
does the cane creek preloader fit to the easton crank? It says it fits Race Face, is that the same cinch as the Easton?
ChiZ01
by ChiZ01
cnynrpr wrote:
Wed Oct 02, 2019 4:00 am
it will fit on any 30mm spindle
UpFromOne
by UpFromOne
Couple questions for the technocrats out there:
1. Does anyone (like RaceFace or ??) make a shorter spindle than Easton's 129mm road cinch spindle?
Like 125 or even 127mm?
2. Does anyone know if the Cinch spindle pattern is the same or different from Hollowgram spindles?
Pardon my ignorance, any info would help.
spdntrxi
by spdntrxi
I know stages spindle A is tiny...
Jhomewood
by Jhomewood
Does anyone know if the easton chainrings shift well?
VTR1000SP2
by VTR1000SP2
Yes
AZR3
by AZR3
Just swapped the stock plastic preload adjuster for the cane creek unit, looks very nice and works perfectly.
UpFromOne
by UpFromOne
Well I rolled the dice and bought a Hollowgram 122mm spindle based on some online photos alone,
and viola', it appears to be the same as the Easton spindles. The Easton Cinch cranks bolt right on.
By using this 122mm instead of the stock 129mm Easton spindle, the Q drops to 143mm (where it should have been in the first place!).
EDIT 11/13: The Stages size "C" spindle is also 122mm, and has the same spline pattern.
I also found out that the SRAM 3-pc crank spindles use the same pattern.
VTR1000SP2
by VTR1000SP2
UpFromOne wrote:Well I rolled the dice and bought a Hollowgram 122mm spindle based on some online photos alone,
Kudos!
UpFromOne
by UpFromOne
spdntrxi wrote:
Tue Oct 15, 2019 3:23 am
Yes, too tiny at only 100.75mm.
And their "B"size is 113.5mm.
DanielNorway
by DanielNorway
Dont think the Stages spindles will work with Easton, the spline pattern has different rotation on DS and NDS.
DaveS
by DaveS
What chain rings are being used for a 46/30? I'd want 12 speed compatible. If the shifting isn't great, the weight savings is worthless.
spdntrxi
by spdntrxi
DanielNorway wrote:
Thu Nov 14, 2019 10:23 am
hmmm.... I never bothered to notice.. Guess I guessed right... my NDS arm is a stages.. Easton on the DS on a stages spindle "C"
DanielNorway
by DanielNorway
Yes, the stages NDS arm has different rotation than easton DS.
Spindles from RF/Easton/Cannondale all has same rotation on both sides.
Stages spindle has different rotation so has to be used with NDS stages arm.
Edit. What I ment in previous post is that you cant use a stages spindle between Easton arms on DS and NDS.
jbattermann
by jbattermann
UpFromOne wrote:
Tue Oct 22, 2019 12:45 am
What tools and/or spare parts do/did you need to switch the Easton spindles with the cannondale ones? Any guides or manuals, videos etc one might look at re: how to swap a stock spindle out..? Would be highly appreciated because I've always been a bit unhappy with the Easton's stock width and q-factor
Cheers,
-J
