Aero Helmet
Specialized Evade II was released together with SW7 shoes 4 years ago.. shoes have just been revamped and in the SW Torch thread they mentioned a new Evade was coming.. Specialized did a big sale on the helmets some days ago.. so everything points in that direction.. dunno when though..
Hopefully soon as I need to replace mine as well
From one side it could happen at TdF, but on the other we haven’t seen any pics on pros yet..
Do you have a close shaven head or a very short hairstyle by chance? I haven’t noticed much wind noise with my Eclipse. I think it’s a fantastic helmet overall.
I have both the Bontrager Ballista MIPS in medium (278g) and the Met Manta MIPS in small (238g). They both feel aero but who knows. I've found them both decent even in hot weather (90+ degrees F).
I guess the Met is probably faster for me as it's a size small, so smaller frontal area. As someone else mentioned, the Balissta has no vent mesh, and twice I've had a bee fly into the inside of my helmet (and I'm allergice to stings).
Finally on the Ballista the headsize adjustment straps broke and Bontrager sent me a replacement at no charge. But there must have been some model change because I had to take out the MIPS liner to make it work. Even got Bontrager to send me a different size replacement... no dice.
2018 Fuji Transonic 2.5 rim (6.90kg)
2020 ICAN AC-388 cyclocross bike (8.41kg)
2021 Trek Emonda SLR RSL H1 rim (5.65kg)
1980s vintage ALAN Super Record (haven't weighed it)
Very short side (2-3 mm), medium top (20-30 mm). Undercut style.TobinHatesYou wrote: ↑Wed Jun 22, 2022 1:00 am
I guess it may also have something to do with the strap which is thinner than Kask. So Kask's strap block more wind that'll hit my ears. I'll try some wind blocker on the strap to verify.
Oh that's another thing. I can only get Giro/Bell straps to lie flat against my face if it's pretty tight under the chin. Other helmet straps like on the Evade II lie flat against my cheeks in all circumstances.
Wonder if the Evade would be lighter if they would make it with the new Mips technology which I have on my new Ventral Air Mips. Inside it looks completely normal without any sign of Mips. I guess Specialized Mips which is incorporated on the straps is lighter than regular but sure what the difference would be there.
Someone asked about how well ventilated the Nytron is. Here in Sweden tha max temperature has not exceeded 21C yet so still hard to judge. It seems good though.
Imo the RP Nytron is as quiet as my Evade 2.
Scott Addict RC 20 2021
Ridley Kanzo Adventure 2022
Not sure if anyone has mentioned this test: https://www.youtube.com/watch?v=8RlTcac7QUg - where Evade came out on top, but Met Trenta came out very, very close. For an airy and light helmet like Trenta, that is a damn good result. Seems like a good choice for climbing.
That seems odd, given how ventilated it is. If that's the case then the Manta should be faster than the Evade you would think.aeroisnteverything wrote: ↑Wed Jun 22, 2022 12:19 pmNot sure if anyone has mentioned this test: https://www.youtube.com/watch?v=8RlTcac7QUg - where Evade came out on top, but Met Trenta came out very, very close. For an airy and light helmet like Trenta, that is a damn good result. Seems like a good choice for climbing.
Weights by the way, all in M.
Evade 2: 261g
RP Nytron 260g
Poc Ventral Air Mips: 256g
Poc Ventral Lite: 199g
The Nytron is heavy, given it doesn't have any extra protection system. It does have the WG11 cerification though, whatever that means.
Evade 2: 261g
RP Nytron 260g
And maybe it is faster than the Evade. Have not seen any tests on it unfortunately. FWIW, I have it and like it very much. I certainly cannot tell any difference vs the Evade II in terms of performance with extensive usage of both. The Manta is lighter, but ventilation is not quite as good as the Evade II.Roadbiker10 wrote: ↑Wed Jun 22, 2022 12:41 pmThat seems odd, given how ventilated it is. If that's the case then the Manta should be faster than the Evade you would think.aeroisnteverything wrote: ↑Wed Jun 22, 2022 12:19 pmNot sure if anyone has mentioned this test: https://www.youtube.com/watch?v=8RlTcac7QUg - where Evade came out on top, but Met Trenta came out very, very close. For an airy and light helmet like Trenta, that is a damn good result. Seems like a good choice for climbing.
People focus a lot on how the front of the helmet looks and whether it has/does not have vents. But I think the design of the back end of the helmet, and how the air is extracted/driven through from the front through the available vents, is a lot more critical to aero performance. Met and Specialized both seem to have done their homework on that point.
I've heard rumours saying it'd be around WC.Matte86 wrote: ↑Tue Jun 21, 2022 8:32 pmSpecialized Evade II was released together with SW7 shoes 4 years ago.. shoes have just been revamped and in the SW Torch thread they mentioned a new Evade was coming.. Specialized did a big sale on the helmets some days ago.. so everything points in that direction.. dunno when though..
Road // 2023 S-Works Tarmac SL8 | Shimano Dura-Ace Di2 | Roval Rapide CLX
Gravel // 2023 Specialized Crux Pro | SRAM Force AXS | Roval Terra CL
Retired // 2022 S-Works Shiv TT // 2021 S-Works Tarmac SL7 // 2019 Specialized Allez Sprint Red Hook
