Sram 10 speed and 11 speed brake lever compatibility
paregreen23
by paregreen23
Hi there
I decided a while back to upgrade from sram 10 to 11 speed. I brought a new 11 speed rear and front derailleur, and also new chainrings. However, I am in doubt now about whether I need to buy 2 new 11 speed brake lever/shifters, or can I keep the 10 speed front shifter and only replace the rear brake lever/shifter?
Hope someone out here can help.
Please let me know your thoughts.
Duncan
Duncan Paré
Parlee Z Zero
Juanmoretime
Administrator
by Juanmoretime
I'm doing the opposite. I have a 10 speed rear Sram Red shifter and my left went bad so I have an 11 speed left shifter, Red 22. It works juust fine with the 10 speed yaw front derailleur I have on my bike.
RESIDENT GRUMPY OLD MAN.
darnellrm
by darnellrm
The ONLY thing you needed to rplace was the rear shifter. Everything else would have worked perfectly.
paregreen23
by paregreen23
Thanks for the responses ...
seems I could have saved my self some money there... oh well I’lI look for a Single rear shifter now :-)
Duncan Paré
Parlee Z Zero
jfranci3
by jfranci3
The part is not findable, so yes buy a whole new shifter. If hydro, the rim caliper shifters can be found cheaper.
