Garmin mounts for Uno Kalloy stems?
addictR1
by addictR1
since many ppl here rock with uno kalloy stems, are there any out in front garmin mounts that would fit the stem? looking for some lightweight solution. currently using k-edge with gopro mount.
whyamihere
by whyamihere
I use the Wahoo version of this: https://www.racewaredirect.co/shop/carb ... ate-mount/
You want to get the 24mm version for an Uno. It doesn't come with a GoPro mount, but as they 3D print the mounts, you may be able to get them to do a custom one.
addictR1
by addictR1
whyamihere: thanks! i like the k-edge how it drops down from the handlebar so the garmin will be flush. besides the raceware.. any other carbon or plastic type that would fit the lightweight standards? i'm in the US, so ordering from raceware might not be cost effective...
1415chris
by 1415chris
With current dolar-pound exchange rate?
Or you can wait till Halloween, it should be even better
addictR1
by addictR1
whyamihere wrote:I use the Wahoo version of this: https://www.racewaredirect.co/shop/carb ... ate-mount/
What’s the weight and is it a strong mount; meaning the garmin doesn’t bounce up and down or around when riding?
Also I took some measurements and 24mm seems a bit tight. I see it around 24.7mm. Did your fit snug on the uno stem?
Marin
by Marin
Made my own mount -> viewtopic.php?f=3&t=158165
alanyu
by alanyu
I bought this when I was in China.
It's not difficult to DIY.
What you need is: 3K carbon fiber board, resin, garmin mount (and gopro mount).
Cut the carbon board into several pieces with a designed shape;
Drill holes for screws and connection;
Glue them...
addictR1
by addictR1
Marin wrote:Made my own mount -> viewtopic.php?f=3&t=158165
Yup I saw your post on that! Love it. I’ll give that a try with some steel coat hangers
Alanyu: yup I saw those on AliExpress too.. but glad I saw Marins diy
