THM tibia stem: which computer mount are you using?
mike
Resident Pro
by mike
you need to use loctite if you want the mount to stop loosening.
tabl10s
by tabl10s
You could also use "Blue Tack" which is a putty that used to keep multi-thousand dollar bookshelf speakers adhered to the stands.
A thin piece is all you need.
2015 Pinarello F8: 13.13lbs/5.915kg(w/Roval 64's).
2016 Rca: 11.07lbs/5.048kg.
2018 Rca.
2018 S-Works SL6 Ultralight: 12.03lbs.
edorwart
by edorwart
AndreLM wrote:
Sun Aug 04, 2019 1:27 am
User @WheresWaldo from this forum has some 3d printed parts that should work better with your Bolt, such as this one: http://shpws.me/OQxZ
This is his thread: viewtopic.php?p=1120276#p1120276
Enviado de meu SM-G950F usando o Tapatalk
FYI - I purchased the 3D Printed one and it works great. The designer also made me a Colnago 64 seatpost mount for Cycliq for me and is great to work with.
FlatlandClimber
by FlatlandClimber
edorwart wrote:
Wed Apr 22, 2020 1:29 am
It looks aero, which is good. But it also looks pretty chunky.
Cervélo S5 Disc (2019) - 7.6kg
Open Cycles WI.DE (2019) - 8.4kg
Specialized Shiv TT Disc (2020) - 7.5kg
Specialized SW Roubaix Team (2020) - 7.5kg
edorwart
by edorwart
I guess one could call it "chuncky" but it is mounted to a THM Tibia which is in every way a "chuncky" stem so it matches the stem design which is a good thing. To have a Wahoo Bolt mounted to a a non-aero toothpick stem like a Carbonworks does not look look astectically correct IMO.
FlatlandClimber
by FlatlandClimber
Good thing, that aesthetics depend on the beholder.
