THM tibia stem: which computer mount are you using?
tabl10s
by tabl10s
I wonder if it'll have the same weave?
2015 Pinarello F8: 13.13lbs/5.915kg(w/Roval 64's).
2016 Rca: 11.07lbs/5.048kg.
2018 Rca.
2018 S-Works SL6 Ultralight: 12.03lbs.
CarbonWorks
by CarbonWorks
Hi guys,
sorry for the long time you had to wait.
But there has been a lot of works and christmas and such things...
finally finished :):):)
Simon
carbonworks.de
TurboTommy
by TurboTommy
CarbonWorks wrote:
Sun Jan 05, 2020 9:19 pm
Hi guys,
Hi Simon, congratulations. Would it be possible for you to measure the mount from the stem face plate to the centre of the mount cradle. It looks like it's quite long compared to my elemnt bolt. Is it possible for you to produce with different length shafts? Many thanks
tabl10s
by tabl10s
Hi guys,
Perspective is everything:
https://gifts.worldwildlife.org/gift-ce ... ush-z1.jpg
I'll take three.
2018 Rca.
CarbonWorks
by CarbonWorks
Distance is about 58 mm.
A shorter version is not planed yet.
I have made many new products and have to fill the website ;)
Simon
carbonworks.de
Mostlyharmless
by Mostlyharmless
[removed - mind your manners] - RyanH
tabl10s
by tabl10s
In this video, it's said that the faceplate was designed for the Barfly system(1:07).
2018 Rca.
njyeti
by njyeti
I had the carbonworks mount and about every 15 rides it would become loose and unscrew itself. I even tried over torquing it out of frustration and still happened. Finally threw it in the trash- too much of a pain having to take the face plate off to retighten. Back to reliable k edge xl.
FlatlandClimber
by FlatlandClimber
The Carbon works one:
Important: this one is not very stiff (which for me isn't important). But if you expect a mount similar to the one they make for normal stems, it's not as rock hard.
Cervélo S5 Disc (2019) - 7.6kg
Open Cycles WI.DE (2019) - 8.4kg
Specialized Shiv TT Disc (2020) - 7.5kg
Specialized SW Roubaix Team (2020) - 7.5kg
tabl10s
by tabl10s
FlatlandClimber wrote:
Mon Apr 20, 2020 8:00 am
How long before it arrived?
2018 Rca.
FlatlandClimber
by FlatlandClimber
tabl10s wrote:
Mon Apr 20, 2020 8:23 am
So little, that I don't remember. Maybe 3 to 4 days.
tabl10s
by tabl10s
Mon Apr 20, 2020 8:34 am
Pre-Covid?
2018 Rca.
FlatlandClimber
by FlatlandClimber
tabl10s wrote:
Mon Apr 20, 2020 4:18 pm
Pre-Covid?
During. Ordered on their website.
AdvanTech
by AdvanTech
njyeti wrote:
Mon Apr 20, 2020 2:53 am
Yep. Same with the BarFly mount though that one wouldn't last nearly as many rides before becoming loose. Eventually the bolt stripped itself after constant retightening. I'll never use another mount off the front of the Tibia again.
FlatlandClimber
by FlatlandClimber
Can't complain about the mount thusfar. I only have big trouble with their bottle cages.
