Softride project
jorisee01
by jorisee01
none wrote:
TimmS wrote:
Tue Sep 03, 2019 8:19 pm
Look ergostem maybe?
I've got one of those, let me know if you need it.
Thanks. I think I've got what I need right now. Ig needed I'll let you know! Much appreciated!
Verstuurd vanaf mijn SM-G960F met Tapatalk
jorisee01
by jorisee01
Received the headset conversion from INN. Looks really well made.
Progress today - took the old headset cups out.
jorisee01
by jorisee01
Internal wires are done. I use speaker wires soldered to di2 connectors. I'll try to install the internal battery behind rear wheel.
addictR1
by addictR1
jorisee01 wrote:Internal wires are done. I use speaker wires soldered to di2 connectors. I'll try to install the internal battery behind rear wheel.
Damn that’s a big hole. Did you do that or was that there to begin with?
Also have you tried internal routing?
jorisee01
by jorisee01
I did that. I want to be able to put the internal Di2 battery in there. I will dremel it to make better edges.
joejack951
by joejack951
addictR1 wrote:
Fri Sep 13, 2019 4:57 am
I think I see the other end of that wire exiting from the frame at some point further towards the headtube.
joejack951
by joejack951
jorisee01 wrote:
Mon Sep 09, 2019 8:54 pm
Received the headset conversion from INNI. Looks really well made.
:thumbup:
jorisee01
by jorisee01
It's almost all internal. Around the BB is still something I need to find out how to do that properly. It now comes out of the frame just before the BB and then enter again in the BB.
jorisee01
by jorisee01
I do have an issue pressing it in. So I ordered a BB press. I used a DIY thing for previous pressfit tasks.
addictR1
by addictR1
jorisee01 wrote:I did that. I want to be able to put the internal Di2 battery in there. I will dremel it to make better edges.
Will look clean after you Dremel it. Image
jorisee01
by jorisee01
She made her first meters. Battery still strapped to the bottle cage so not pictures just yet. Also want to get the position right first.
