Cannondale SuperSix Evo HM 2020 Custom Build
alexneumuller
by alexneumuller
Wheels were purchased from Edelrad.de
IF Crown Jewel TI
Open New UP
Stinner Ti
Speedvagen
Parlee Z-Zero Disc
Cannondale System Six
Cielo Road Racer
Cervelo P5 Disc
English Cycles 10th Anniv Edition
Cannondale Super Six Evo Disc
floppyb
by floppyb
I'm surpised those rims are only 18m interal width. Thought the industry was moving towards wider. What size tyres are you running on them?
Dan Gerous
by Dan Gerous
floppyb wrote:
Mon Nov 18, 2019 5:30 am
DT Swiss have always lagged a bit behind in that regard... but given the priority of these wheels was probably low weight, it's not entirely surprising. They probably don't expect consumers of these to ride very wide (read heavier) tires anyway, and being so shallow, aero was probably not a priority either.
mancampmartin
by mancampmartin
I've been combing through this thread as I am in a similar situation.
Just picked up a 2020 Supersix Evo Hi-Mod Disc Di2 and looking for some advice on how to cut weight. It seems like low hanging fruit might be to consider doing away with the Vision FSA chanring and Power2Max power meter for a Cannondale SpiderRing and 4iiii Precision meter. I see you went with the Exralite rings. Are those even lighter? Next up is likely a cockpit revision, I'm just running the stock Hollowgram Knot Stem and Systembar currently. Love how it tucks cables but overall the size is quite blocky.
Dollars are less of a consideration. Really just looking for a couple alterations to get this thing sub 7kg. Appreciate any pointers.
2020 SuperSix Evo Hi-Mod
Plant Powered Pedal Pusher
:beerchug:
mancampmartin
by mancampmartin
:beerchug:
alexneumuller
by alexneumuller
I currently have 28mm Victoria Corsa Controlled installed.
floppyb wrote:I'm surpised those rims are only 18m interal width. Thought the industry was moving towards wider. What size tyres are you running on them?
IF Crown Jewel TI
Open New UP
Stinner Ti
Speedvagen
Parlee Z-Zero Disc
Cielo Road Racer
Cervelo P5 Disc
alexneumuller
by alexneumuller
The Cockpit wasn‘t my target to loose weight.....I just went with what I feel most at home with.
I had Praxis Works Chainrings on before and they were heavier. Will see how it all works out....still got the praxis ones and can always go back to them...as the extralite have some more flex in comparison
mancampmartin wrote:I've been combing through this thread as I am in a similar situation.
IF Crown Jewel TI
Open New UP
Stinner Ti
Speedvagen
Parlee Z-Zero Disc
Cielo Road Racer
Cervelo P5 Disc
mancampmartin
by mancampmartin
Got it! I realize it's all a give/get scenario. Cut some weight, lose some rigidity or comfort. Seems like you've found a pretty optimal medium.
I'll do some research on the cockpit component. I really like how this current SystemBar feels but I imagine if I swapped over to a more traditional configuration I could save some weight.
Any other suggestions or major focus areas? Perhaps looking at chain rings and crankset next?
alexneumuller wrote:
Mon Nov 18, 2019 5:23 pm
:beerchug:
hannawald
by hannawald
Cannondale SISL crankset incl. powermeter is pretty light from what i recall..
If you want to go really light, take Extralite wheelset (sub 1100 grams). For normal riding i would take carbon ti hubs/dt180 exp hubs with 46mm light bicycle rims. You will be sub 1400g with wheels.
For under 7kg you will need to swap the cockpit..stock one is heavy.
Take Hutchinson Fusion 11Storm Galactik 25mm tubeless tyres, pretty light and great on rolling resistance.
alexneumuller
by alexneumuller
Tomorrow we have sunshine I think. Will finally take some pics to showcase it better. Image
IF Crown Jewel TI
Open New UP
Stinner Ti
Speedvagen
Parlee Z-Zero Disc
Cielo Road Racer
Cervelo P5 Disc
floriansantana
by floriansantana
Mon Nov 18, 2019 5:30 pm
If you want to shed some serious weight it starts with the cockpit, you can save 300g only in that. Then go tubeless or really light tubes like Tubolito, it saves you another 200g at least. From there, it gets harder to lose weight, because then only small amounts can be shed by swapping the Power2Max with the Spiderring, going for a lighter saddle, lighter rotors, and so on.
alexneumuller
by alexneumuller
IF Crown Jewel TI
Open New UP
Stinner Ti
Speedvagen
Parlee Z-Zero Disc
Cielo Road Racer
Cervelo P5 Disc
burglarboycie
by burglarboycie
Love it!!
romanmoser
by romanmoser
wheels tested quite unaero on the last canyon ultimate slx evo aero test by german magazines
bikebeat 45mm would have been better choice I think
alexneumuller
by alexneumuller
Wasn‘t looking for Aero wheels, but pure climbing/descending wheels that I feel Good on. Plus the DT Swiss come with their new hub system.
And Must admit that I just had to google Bikebeat wheels, as I ve not Heard from them. They don’t fit my requirement so they are not an option. For Aero wheels I have a set of Hunt 45Limitless as an option. I feel they are better just from specification wise in comparison to the bikebeat
romanmoser wrote:wheels tested quite unaero on the last canyon ultimate slx evo aero test by german magazines
IF Crown Jewel TI
Open New UP
Stinner Ti
Speedvagen
Parlee Z-Zero Disc
Cielo Road Racer
Cervelo P5 Disc
