Cannondale supersix himod headset issue
samarskyrider
by samarskyrider
Anyone knows where to source upper bearing only?
skyliner1004
by skyliner1004
In this thread, is the ss headset issue related to a creaking when standing up and putting down the power in the handlebars/stem, or is it related to a loose steerer tube feeling?
2018 Supersix Evo Hi-Mod Disc Dura-Ace
Conti SS + Gp5000
3t Ernova Team
Garmin 520 Plus
Look Keo Blade 2 Carbon Ti
15lb 15oz
samarskyrider
by samarskyrider
skyliner1004 wrote:In this thread, is the ss headset issue related to a creaking when standing up and putting down the power in the handlebars/stem, or is it related to a loose steerer tube feeling?
I believe to both of these things. I've replaced the headset altogether with cone piece on the fork. Looks like compression ring (alu piece) is not compressing enough. I had to put a small shim between the compression ring and headset cap (black aluminum with Supersix lettering).
Wobbly feeling on front brake is gone, but I can still hear creaks from the headset (I believe it has something to do with ovality)
New headset has a small plastic ring that seats between lower bearing and fork piece
This is how it looks now with a small shim under headset cap
