Travelling with disc brake bike
Boshk
by Boshk
Anyone encountered any problem while travelling (airline) with their disc brake bike, especially those with hardcases where you need to remove and turn the handlebars and fork?
jfranci3
by jfranci3
If centerlock, pull the discs off so they done get bent.
hkgmatt
by hkgmatt
I usually take the rotors off and put them into the case separately. I also put spacers into the calipers in case the levers get pulled accidentally. I have had no issues on multiple trips.
moyboy
by moyboy
Transported disc brake bike with bothe the scicon tsa evo and topeak pakgo x. No issues. I usually bring a rotor tuning fork just in case.
Disc brake spacer is a good practice. Extra padding and a layer of bubblewrap for good measure.
Boshk
by Boshk
Thanks, how about the hydraulic cables though, specifically when you remove the handlebar from the stem and rotate it..... Possible leaks?
morrisond
by morrisond
You should have no worries - they are quite robust - unless your cables are too short and there isn't enough slack to turn your bars.
ms6073
by ms6073
morrisond wrote:
Thu Jul 25, 2019 2:44 pm
While not directly on topic, given the rise of the all-intern hydro disc brake bikes, wonder how one travels with those bikes as there is next to no extra hydro hose.
LeDuke
by LeDuke
Then you don’t have a bike built to survive a crash, or the relatively mundane rigors of travel.
morrisond
by morrisond
ms6073 wrote:
Thu Jul 25, 2019 3:08 pm
If it's all internal I would assume that the hydro hoses go through the steerer tube or right next to it - so it shouldn't be issue as the hose itself will rotate and it doesn't need to wrap itself around an Head Tube.
edwardk
by edwardk
I recently traveled trans-Atlantic with my bike with Campy H12 discs, using a super compact soft case (so that I had to remove the fork/handlebar assembly from the frame), and had no issues with brake fluid leaks or rotor issues. I probably will pull off the rotors next time out of an abundance of caution. Caliper blocks strike me as indispensable, given how everything gets compressed in a soft case.
I did carry a spare rotor with me, which proved to be prescient, as Campy gear is not easy to find in every small town, even in France. My front rotor needed replacement after a low speed crash of the most embarrassing sort — leaving the front wheel propped up on the side of the car, loading the bike, and driving off without the wheel.
Edward
