Anyone running their Madone SLR's with TL 28mm's?
Noctiluxx
by Noctiluxx
I have a 2019 Madone SLR rim brake currently with 25mm Conti 5000 clinchers. I'm thinking of trying the 28mm Conti 5000 TL's for replacement. What are the advantages/disadvantages of the bigger 28's? Thanks!
2018 Bianchi Oltre XR4, (Celeste Matt)
2018 De Rosa SK Pininfarina (Blu)
2019 Trek Madone SLR (Rage Red)
2019 Giant TCR Advanced SL (Chameleon Blue)
2019 Cervelo R5 Disk (Team Sunweb)
2019 Giant Revolt Advanced 0
TobinHatesYou
by TobinHatesYou
Noctiluxx wrote:
Sat Jul 20, 2019 5:15 am
The big disadvantage is you need properly wide rims (think 30mm) to get the best aerodynamic performance out of those tires. The advantages are you can run lower pressures...you'll be less likely to puncture when running over debris, you'll be more comfy.
wheelsONfire
by wheelsONfire
Tyre pressure and rolling resistance
“It is true that the higher the inflation pressure, the lower the rolling resistance of the tyre,” Schwalbe UK’s Dave Taylor says. “It’s also worth pointing out that a tyre’s susceptibility to punctures is lower with high pressures, too. And if the inflation pressure is continuously too low, premature tyre wear is the result, which usually means cracking of the sidewall and unnecessarily high abrasion.”
Read more at https://www.cyclingweekly.com/news/prod ... 1ir3mq5.99
Bikes:
viewtopic.php?f=10&t=156137
Open *UP* (2016.04.14)
Ex bike; Vial EVO D
jasonh
by jasonh
I recently switched from 25 to 28’s. The comfort benefit is obvious to me, but leaning hard into corners is definitely better. I’m sure it has much to do with my confidence as opposed to anything scientific. But it’s just better whether I’m on a mediocre tire or a decent tire.
I won’t be going back to 25’s.
jasonh
by jasonh
I should add that the comfort and cornering was astonishing using 32’s, but they just felt too slow climbing, especially on a 14% grade in my area. It makes me want to try some of the Compass tires, which are big and lightweight.
alcatraz
by alcatraz
My friend is running his madone (rim brake) with 28C gp5000 tires on a wide rim. The tires blow up to 32mm at their widest point. They actually fit the bike but with little clearance. The front wheel has less clearance than the rear.
The largest tire you can fit will depend on your inner rim width, tire kind and size.
A 32c tire could be fine on a narrow rim while a 28c could rub on a wide rim. Be careful.
Vittoria tires measure small (25c = 24mm on my wheel) and continental measure big (23c = 25mm on my wheel).
spartan
by spartan
i use 28rear/25 front conti5000 TL on madone slr on dt erc wheelsets.
Current Rides:
2018 Madone SLR DISC DI2 9XXX
2017 Giant TCR Advanced SL 0 DI2 9150
