Tubolito Blowout!
tabl10s
by tabl10s
My blowout was a year ago and no more problems. I use lightweight cloth rim strips.
2015 Pinarello F8: 13.13lbs/5.915kg(w/Roval 64's). Sold.
2016 Rca: 11.07lbs/5.048kg.
2015 Rca. 11.15 lbs(w/Roval CLX 32's)
2015 Rca/NOS(sold).
2018 S-Works SL6 Ultralight 12.03lbs(w/Roval CLX 50's)
tmchen
by tmchen
Anyone used it recently? I heard it is better to be used on DB wheels than rim brakes due to the heat generated.
Klaster_1
by Klaster_1
tmchen wrote:
Wed Aug 05, 2020 7:25 am
You mean Tubolitos? I've been running these since 2018, not the best experience, but a lot of mistakes on my part too since I used to run mostly tubeless before. First gen patches (transparent) are very unreliable though, current thick black/orange patches hold much better. Had a bad steak of failures this year: snake bite from tram line edge at high speed; blade-like sharp piece of glass; car tire wire; sidewall torn by a pothole edge - not sure how other tubes would have been better in most of these situations.
DC41
by DC41
Saw the subject for this thread, and my first thought was someone had them on sale! :lol: :oops:
Self-Proclaimed Resident Master Fattie - Vicious DC Slither
tabl10s
by tabl10s
DC41 wrote:
Wed Aug 05, 2020 11:06 pm
Bwahahaha!
2015 Rca/NOS(sold).
robbosmans
by robbosmans
My tubolitos have been great for almost 1000km now, no issues
Johnny Rad
by Johnny Rad
Necropost... beware, but I couldn't help myself.
I've successfully run latex tubes and Veloplugs for >5yrs.
I'm just sure the Veloplugs are fully seated with no sharp edges sticking-up.
dastott wrote:
Fri Jul 19, 2019 4:40 am
I have wondered about using latex tubes with veloplugs (I know Tubolito are a little different to latex...)
extrusionedwin
by extrusionedwin
any recommedation with this issue??
take a look here the picture
can I still using it?
MikeD
by MikeD
extrusionedwin wrote:any recommedation with this issue??
Did the tube melt from braking heat?
extrusionedwin
by extrusionedwin
only expand 15cm in this section, the wall thickness is very thick. I don't know if this affects to reuse again??
wickedstealthy
by wickedstealthy
Running tubes already for 8000km this year. Patched one. The new glue is actually camplast and can he bought separately. And I just use a tubo as patch material. The patched tubo already runs for more the 5000km and holds air for days.
Leaking valve ? The early ones had issues and I didn't experience them anymore. As it's a hard tpu to metal bond just use superglue or the camplast glue from the patchkit. No problem leaking anymore.
Btw I use the regular tubos in carbon rims in Spain +30
Holliday89
by Holliday89
robbosmans wrote:
Thu Aug 06, 2020 5:56 pm
2 fold!
Used in 3 differnt bikes for over 3 years. All rim brake & no issues at all
mashiehood
by mashiehood
hve been in my Enve 4.5's for almost 2 years, barely lost any air and have been fit and forget (touch wood)
req110
by req110
Whatever happens, just contact their customer support. They were really helpful and i got replacement very quickly.
SW SL8 RTP 56cm @ 9270 / CLX II / CS OSPW / CEMA BB
S Epic 8 L @ XX T-Type / Berg Ratheberg 30 / Quarq / Fox Transfer SL 100mm / 3p
