Tubolito Blowout!
On the rear end of a 30 ride. It was 81 degrees and I was climbing around a rock slide from earlier in the year. Once across, "POW"!
Upon inspection, there was a hole and four expansions(bubbles)spaced out around the tube. No thorns, glass or anything present in the tire.
2015 Pinarello F8: 13.13lbs/5.915kg(w/Roval 64's). Sold.
2016 Rca: 11.07lbs/5.048kg.
2015 Rca. 11.15 lbs(w/Roval CLX 32's)
2015 Rca/NOS(sold).
2018 S-Works SL6 Ultralight 12.03lbs(w/Roval CLX 50's)
2015 Rca/NOS(sold).
Not surprised to hear that. Nothing but problems with them in our group of riders.
Hopefully you didn't crash from the blowout.
Current Stable. Evo (Storm Trooper) : 5.39kg | Alchemy Eros : Heavy (7.25kg) I Specialized Allez Sprint 2022 : Heavy (7.62kg)
I was walking. I have plastic plugs in place of a strip and my friend said one had dislodged when he took the tire off.
Have no idea what caused the bubbles which seem to be permanent.
2015 Rca/NOS(sold).
2015 Rca/NOS(sold).
Were those regular or S-Tubo? Rim brake or disc brake?
- wheelbuilder
My shop went through this rash of installing these for several customers that all brought them in within a 10 day period. There must have been a lot of talk online about them cause they were hot and the new thing to have. I would say that 8 out of 10 of them had leaking valve tubes from the get-go or deformed valve tubes within a couple of weeks due to pumping them up or checking pressure daily. The plastic valve tube with metal core is a super poor design.
Rim. Was the first question about tires?
2015 Rca/NOS(sold).
2015 Rca/NOS(sold).
No, the tubes: there are regular (43g) and S-Tubo versions (23g, disc only). I had no issues with my regulars until I punctured one and the patch did not help.
This exact same problem. We probably experienced the same failure rate at 12 out of 15 riders.wheelbuilder wrote: ↑Fri Jul 19, 2019 5:44 amMy shop went through this rash of installing these for several customers that all brought them in within a 10 day period. There must have been a lot of talk online about them cause they were hot and the new thing to have. I would say that 8 out of 10 of them had leaking valve tubes from the get-go or deformed valve tubes within a couple of weeks due to pumping them up or checking pressure daily. The plastic valve tube with metal core is a super poor design.
Mine say 37g on the package.
2015 Rca/NOS(sold).
2015 Rca/NOS(sold).
